Variable ND filter
Can anyone recommend a 58mm variable ND filter with an outer thread allowing a lens hood to be attached?
Re: Variable ND filter
Hi Jerry,
I have two slightly different ones, a Kenko which allows me to use the bayonet fitting hood on my lenses and a slimline Fotga one which is larger overall diameter, much thinner, but is threaded to allow a screw fitting hood. Both are for Canon EOS lenses and are both are budget filters as I rarely use them but wanted to experiment. Roger Edited to say I just realised you want them for a Canon video cam, but the 58mm thread should be the same. |
