-   Canon XA and VIXIA Series AVCHD Camcorders (https://www.dvinfo.net/forum/canon-xa-vixia-series-avchd-camcorders/)
-   -   Internal diameter microphone holder XA10 (https://www.dvinfo.net/forum/canon-xa-vixia-series-avchd-camcorders/502579-internal-diameter-microphone-holder-xa10.html)
Jo Ouwejan November 11th, 2011 10:22 AM
I am thinking of buying a Canon XA10 and for that reason I would like to know what the ID of the microphone holder is. To see whether my Sennheiser would fit in. Can anyone tell me that?
Don Palomaki November 11th, 2011 11:28 AM
Re: Internal diameter microphone holder XA10
It is about 1". Common video microphones such as the Rode NTG-2 (22 mm diameter) or Audio-Technica AT-875 (21 mm diameter) need small spacers on the body to hold them snug. My AT-875 came with O-rings for this purpose and they work great.. I used a few turns of gaffer tape on the NTG-2 body to keep it snug.
Which Senn do you plan to use?
Kawika Ohumukini November 11th, 2011 11:41 AM
The holder has little rubbery fingers that are about 7/8" ID and will compress to 1" as Don said. I have the AZDEN SGM PDII which is only 13/16" in diameter which is loose but it also comes with a rubber spacer that fills the gap nicely. Cheers
Jo Ouwejan November 11th, 2011 11:53 AM
My Sennheiser is 22mm as well, so I will need to acquire a couple of O-Rings. No big deal.
Thanks for the input.
Mark Goodsell November 12th, 2011 09:37 AM
I have a Senheiser mic I use in mine. You will need to add something to make it tighter. I have a thin piece of soft rubber I wrap around my mic one time and it works great. Mics vary in diameter, I'm sure they designed it to accept the larger popular mic sizes. I've needed to do the same thing using Senheiser mics on other cameras.
Charlton Chars December 21st, 2011 10:50 PM
I have used this multiple times and it holds well.
Mark Goodsell December 22nd, 2011 05:26 PM
My Sennheiser fits fine. I have a thin piece of rubber I wrap around it. My Sony Z5 requires the same piece of rubber too.
