-   Canon XA and VIXIA Series AVCHD Camcorders (https://www.dvinfo.net/forum/canon-xa-vixia-series-avchd-camcorders/)
-   -   2GB file size limit on XA10? (https://www.dvinfo.net/forum/canon-xa-vixia-series-avchd-camcorders/492882-2gb-file-size-limit-xa10.html)
Chris Anderson March 9th, 2011 06:48 PM
Hello - super interested in the XA10 camera (whenever it is released). Does anyone know if there is the 2GB file size limit that seems inherent to most AVCHD cameras?
Michael Murie March 17th, 2011 08:29 AM
Re: 2GB file size limit on XA10?
I don't know about the 2GB limit, but this article says that SDXC and the FAT32 filesystem it uses is limited to 4GB:
Introducing SDXC and exFAT in Apple Mac OS X – Stephen Foskett, Pack Rat
Interestingly enough, the manual for the HF G10 says that Mac OS X doesn't support SDXC (as at October 2010) though the above article suggests otherwise.
Also, the manual says that there will be a short pause in recording after 12 hours of recording, no matter how large a card you are using...
