-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   1080 24f > SD (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/94450-1080-24f-sd.html)
Glenn Gipson May 19th, 2007 04:58 PM
1080 24f > SD
What is the best way to down convert my 1080 24F footage to Standard Definition? I have Vegas, but when I down convert to SD, the footage stutters and has a horrible motion blur to it.
Mike Dulay May 19th, 2007 05:19 PM
You can try steve's 24p pulldown to get rid of the interlace blur. To retain the nice output you need to pick an SD format that is also progressive.
http://www.dvinfo.net/conf/showthread.php?t=94235
Austin Meyers May 19th, 2007 10:08 PM
are you outputting to dvd? if so you're in luck as it supports 24p m2v's and you can get more on a disc as the filesizes shrink accordingly, the stuff i've tested making 24p dvds looks really good
Glenn Gipson May 20th, 2007 04:20 AM
Yes, but the reason why I want to downrez is because I don't really have the cash to edit HDV.
Povl H. Pedersen May 20th, 2007 01:38 PM
HDV can be edited with standard tools on standard machines. iMovie and Final Cut Express HD both do a good job for little money on modest hardware.
Glenn Gipson May 20th, 2007 03:59 PM
I have a PC though.
