TL-H43 telephoto zoom
Has anyone tried this with the HV20? I am specifically interested in knowing if there is ANY vignetting when the HV20 is wide-open (1.8 aperture)? There are reports that the TL43 (no H) does show some of the adapter at wide angle and you'd need to zoom the HV20 to zoom past it. Thats not going to work for me. I especially need to stay wide-open in order to keep the aperture at 1.8 for low-light shots (I'm using a 35mm adapter so every bit of light is precious).
Thanks! Rob Robinson |
I'm a bit confused.. you don't intend to use the wide angle lens with the 35mm adapter, do you?
I have use a Brevis and I own a different wide angle lens, but I don't use either at the same time. |
Canon Tele-Converter TL-H43 1.7x
I am using Canon's TL-H43 1.7x with my HV20.
The TL-H43 also shows some of the adapter at wide angle. It works very well at high zoom, but not at wide angle. |
doesn't the tele adapter also move the minimum focus distance out by 1.7x as well? so using it instead of a macro type lense wouldn't be optimal... correct me if i'm wrong anyone.
You will need to verifty first if the TFH43 has front threads.. the wide angle sadly doesn't.
Something else I've been considering is just using two achormats together inline. I was wondering how to figure out what size that would magnify the GC and would that be "too big" now for the wide open on the HV20. Maybe not....
as far as the missing filter rings on the converters what about something like this?
http://www.bhphotovideo.com/c/produc...p_On_Step.html |
i should get my tl-h43 on tues, at which point i'll measure it's OD and probably order a clamp on step up so i can put a UV and or polarizer on it, although i might run the polarizer inbetween the tl and the cam, just have to wait and see
got my TL-h43 today, it's much heftier than i was expecting
http://file.meyersproduction.com/hv20/tl-h43.jpg http://file.meyersproduction.com/hv20/tl-h43%202.jpg http://file.meyersproduction.com/hv20/tl-h43%203.jpg and here a movie zooming through with and without. http://file.meyersproduction.com/hv20/tl-h43%20test.mov also i'm going to get a clamp on step up ring...probably this one, as the OD is 74.5mm as stated by the lense cap that is included. http://www.bhphotovideo.com/c/produc...p_On_Step.html |
Thanks Austin,
Wow seems like to me that only half the zoom range is usable to avoid vignetting. Although at the long end of the zoom it was nice to see twice as much. This defintely lets me know that I need to keep looking at other options. |
