Intensity Card software update, but does it...
Intensity Card software update, but does it fix the HV20 issue or not?
http://blackmagic-design.com/support/software/ |
i don't recall the exact post but i do remember it was mentioned here,, the output of HDV gets downrezzed before white balance. the input is at full HD resolution. (if i am not mistaken)
the intensity and the hv20 work just fine together already.
terence |
Yes it has ben discussed in a previous post that they work fine together. i believe the original problem was with the type of cable that was used.
I've read the whole thread where you talk about getting the Intensity to work with HV20. That's great news! But why hasn't BlackMagic commented on it or publicly acknowledged it's working? The last post from Tristian Lam on May 8th shows they're having trouble getting the HV20 to work. And then another poster reported on May 9th Black Magic again saying it doesn't work. Since then nothing from them. Sure, they've been busy with the new software update today, but I still have my doubts.
I don't doubt it's working for you. But I'm concerned you are the exception, rather than the rule. I want to hear from Black Magic that it's working before I spend ~$1k for a intensity/card enclosure system for my laptop. |
it is odd that they have not commented, weve been in email contact with them about various other things, and they respond quickly.
the original person posting that he had issues found it to be a cable. most everyone else posting "it doesnt work" including the link you referenced, does not seem to have first hand experience but is rather just repeating what others with no first hand experience have repeated. there are a few others that had issues if i recall, but none have commented yet on cable changes. as far as black magic saying it doesnt work... im still not clear on whether they actually have a cam for testing, they may just be again repeating selected customer comments. so far, i know 3 different working systems, and im all but certian it will be 4 when i pick up my cam tomorrow. so while i see you being skeptical about spending a bunch of cash, id say its a 99% safe purchase. getting it working with a notebook using the magma, or my own external box, now thats a second challenge which i hope to have results on very soon :) terence |
It is not working here. I still get 480i only.
HDMI output from my HV20 is fine to HDTV. It recognizes a 1920x1080 target and does 1080i. With the Intensity, the HV20 sees a DVI target and does 480i. I have one of these Impact Acoustics Velocity HDMI cables on order. I'm not holding out much hope for that though. It's some money thrown to the wind on a single report. Even if that works, I think it's hardly the case everything is just fine between the HV20 and Intensity. Blackmagic Design seems like a good company and I feel confident from what I've seen that they'll make it work reliably across the board. |
Odd. |
Since Kristian does not regularly participate here, there has simply been no update. I don't think that colors them as being non-responsive, not caring or not knowing. I'll send an email and see if we can find out what the customer service response is. |
The issue is definitely related to what kind of HDMI cable you are using. I own 2 different brands of cables. Both are brand new and supposed to be able to do 1080i. One works, the other doesn't. There doesn't seem to be a logical reason for this. It might be good to make a list of all the brands that work/don't work and post it for others so they don't waste their money on a bad cable. |
If you assume that they're non responsive, non caring and/or don't know, then there's no confusion. If you were to assume all those things, then you shouldn't be surprised at all that an end user was the first to make it work. I'm saying that the company that makes the product that specifically picked up an HV20 to test it would be the people who would know if it works or not. If they say it doesn't work (or that there's "no good news") then I have to believe that they do not have it working. And that's why I think it's odd that a third party, who has nothing to do with how the camera works, or how the card works, would somehow be able to make it work when the people who make the card have, apparently, not been able to make it work. Perhaps they've gotten it to work and just haven't mentioned it, but considering they tried hard to get an HV20 while they were in Vegas, and then got ahold of one as soon as they could in Australia, one would think that they would let potential customers know if it worked. Particularly after saying/implying that it did NOT work with the HV20. |
I was merely pointing out, in addition to what you wrote, that the single Blackmagic person who has been here is not actively involved or regularly participating on this forum, so essentially there is no particular significance that can be placed on there being no comment. There have been a few posts that have contained at least an undertone that Blackmagic is being strangely silent or that a company announcement should be expected here. |
Hey, if it works, I'll take it, but any compliant cable should work. I view finding a cable that works to be a fluke workaround, not a true solution. It's not even a matter of expensive (read "higher quality") cables working. The Impact Acoustics Velocity is a cheap cable. It's a third of the price of Impact Acoustics Sonicwave HDMI cable, which is guaranteed to pass 1080p, but doesn't work with my HV20 and Intensity. I hope to have a Velocity Monday. So Derek, what OS do you use? I'd be really curious to know what does your HV20 setup menu say say about your connection when your on the working cable vs a non-working cable? Mine says "1920x1080i" (and outputs 1080) when connected directly to an HDTV or a HDMI computer display that is 1680x1050. http://www.rccvideo.com/int1.jpg When it's connected to the Intensity, it says "DVI" and outputs 480 http://www.rccvideo.com/int2.jpg |
Those screenshots are exactly what I get: the 1920x1080 for my good cable, and DVI for my bad cable. I've got a Intel Core 2 Duo 6600, Nvidia 7300 GS, NOKIA CRT 22", running WinXP Professional 32bit. Have you tried doing a clean install of your operating system? I was going to try that right before I stumbled across it being the cable. |
