-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   My Setup - Part Deux (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/93967-my-setup-part-deux.html)
Peter J Alessandria May 13th, 2007 08:29 PM
With the recent addition of a Beachtek DXA-2s, I'm able to use my AT897 on camera as well as on a boom. (The tripod is a Velbon Videomate 738.)
http://photos.imageevent.com/24peter...e/IMG_3978.JPG
More pics here:
http://photos.imageevent.com/24peter...e/IMG_3980.JPG
http://photos.imageevent.com/24peter...e/IMG_3990.JPG
Bob Zimmerman May 13th, 2007 08:48 PM
Man that is sweet. So the mic stays out of the picture?
Peter J Alessandria May 13th, 2007 11:33 PM
Well the Kid Stays in the Picture, but the mic doesn't ;-) I was so sure it would encroach on the frame I almost didn't even try. But turns out you could get a mic almost twice as long on there, even with the wide-angle adapter.
I've posted elsewhere you could use the AT897 without the Beachtek. You just need a rather inexpensive XLR-to-mini cable. However, you'll only get sound on one channel that way. The Beachtek has a switch to record the mono signal on both channels, so while it's not stereo, at least one channel isn't missing when you play it back on a TV.
Mark Joseph May 14th, 2007 12:35 AM
Nice shock-mount, I've got a problem in that the Sennheiser MKE-300 attaches directly to the shoe, but I like to insulate it from the body to reduce camera operation noise. With the plastic body and shoe mount of the MKE300 it's not really suitable for rubber mount, but I gues it could fit in.
Bob Zimmerman May 14th, 2007 06:36 AM
I found this and it has the mini cable. I wonder if later you would buy the Beachtek can you just change the cable so you have a XLR jack on both ends?
http://www.bhphotovideo.com/c/produc...icrophone.html
John Hotze May 14th, 2007 09:59 AM
It looks like the photo shows about a 1 foot XLR plug on both ends. I'm sure it's a Male to Female.
Jaser Stockert May 14th, 2007 06:42 PM
peter,
what shoe mount mic holder is that and how much does it cost? thanks!
Peter J Alessandria May 16th, 2007 07:31 PM
Originally Posted by Jaser Stockert (Post 679248)
peter,
Rode SM3 - $49.95 - http://www.bhphotovideo.com/c/produc...hockmount.html
Note: the SM3 has two little metal "feet" on the shoe mount that need to be cut/ground off in order to drop down into the HV20 hot shoe.
Here's a kit if you don't want to get the Beacktek -
But note: the kit only records mono - one channel only. Need to duplicate it in post to have audio on both channels.
