-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   Windows media player with reverse 3:2 pulldown? (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/93328-windows-media-player-reverse-3-2-pulldown.html)
Peter Frollo May 6th, 2007 07:23 AM
Is there a Windows media player with reverse 3:2 pulldown so I can utilize HV20 in consumer manner or do I need PAL version to enjoy progressive frames out of the box without a need for prior encoding using reverse 3:2 pulldown?
Mike Dulay May 6th, 2007 11:50 AM
Use VLC Player. It has an option to deinterlace.
Fergus Anderson May 6th, 2007 01:38 PM
for watching 24p on the fly media player classic can do IVTC to give you true 1080-24p in real time. To do this you will need to install Dscaler5 and an older version of the IVTC mod and then change the Dscaler settings in the filter options in MPC
Ali Husain May 6th, 2007 06:08 PM
vlc player is great. but just to be sure: deinterlacing is not the same as 3:2 pulldown (i know you know this mike, but for newbies...):
(1) deinterlacing --> making a natively interlaced stream look like it's progressive
(2) 3:2 pulldown removal --> making a natively progressive 24fps stream stored in an interlaced container actually 24 fps progressive
Ali Husain May 6th, 2007 06:09 PM
unfortuantely, i don't think there is aNY player that will play 24fps hdv footage with 3:2 pulldown added. i convert with software (such as cineform connect HD) first.
Fergus Anderson May 7th, 2007 02:42 AM
Ali yes there is as per my post above!!!!
you can perform on the fly IVTC in MPC using Dscaler5 and the IVTC mod
