-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HV20 Swamp Footage (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/91309-hv20-swamp-footage.html)
Austin Meyers April 11th, 2007 09:34 PM
HV20 Swamp Footage
some footage i shot over the weekend out at Caddo Lake. 3 movies, each are the same, but at a different resolution so you can watch the SD version before you bite off the big one. it's about 15 min long.
http://file.meyersproduction.com/hv20/caddo/
Check it out. I'm planning to get back there ASAP, as last weekend it was in the 30s/40s and didn't make for good exploring. I also got the chance to check the footage out on an HDTV while i was out there and it looked much better on the tv than on my monitor.
Mark Patrick Anderson April 12th, 2007 12:08 AM
I watched a little of the SD version. I like all the greens. Reminds me of the location for the movie 'Southern Comfort' with Powers Boothe. Great flick.
This looks like 60i. Did you have this on the HDV 24fps setting or 30fps? Were you in a boat and was it all handheld? Fantastic location.
Ray Bell April 12th, 2007 04:47 AM
The footage looks great and flows well with the audio....
whats the name of the song??
Javier Gallen April 12th, 2007 05:37 AM
Incredible footage. The enviroment looks amazing and the shots are very stable. O_o
I want to know if it was handheld too.
John Kristoffersen April 12th, 2007 07:39 AM
I just finished downloading the full size clip, and it will not play. I tried Media Player Classic, VLC, and Quicktime Player.
John
Andreas Dahlstrom April 12th, 2007 07:54 AM
The same problem here. :/
Jason Brown April 12th, 2007 08:26 AM
me three...
Austin Meyers April 12th, 2007 09:26 AM
video problems
ok it wouldn't dl for me either, so i'll upload a zipped version with par files.
it's uploading and should be up in about 4 hours. i'll post up again when it's ready.
i shot all it on a tripod. i just took the boat out and would get a little head of steam and then shut it down and let the drifting do the panning for me. and on some of the other moving shots i was sitting in the front of the boat holding the tripod against my body so the bottom of the center column was about on my chest and 2 of the legs were resting on top of my legs.
i shot it all 60i and then deinterlaced this stuff for the web.
the songs are blowout and over the line repectively, both by crystal method.
it's a photography's dream out there, it's 25,000 some odd acres of swamp/lake. i've only been able to cover a marginal amount in my short weekend trips up there. i'm hoping to break away from work and spend a week or 2 up there and get deep in the swamp and see what there is to see.
Tony Parenti April 12th, 2007 09:43 AM
I'm assuming you deinterlaced to 30fps??
Is this is norm for processing 60i video???
I'm looking to get into post processing.
Arvid Kraght April 12th, 2007 09:57 AM
Nice nature and images too but the whole video looks like a little bit soft ..thanks.
Austin Meyers April 12th, 2007 10:07 AM
swamp
it's the down rez'ing and compression, i've got one more tape i'm capturing right now, and i'll post up some full rez screen shots. the compression flattens the color a bit too.
Austin Meyers April 12th, 2007 10:12 AM
it really depends on what the final format is going to be. if the final product is for web, then it's good to deinterlace, as it will cause some weirdness on progressive screens, but if you're final will be seen on a regular interlaced tv then you don't need to worry about it. i'm amazed how much less crisp this stuff looks on my comp verses an HDTV, which makes me really want to get an hdtv. the interlacing is also apparent in the 24p stuff with the pulldown in place, on a comp it looks like every 2 frames are screwed up, but on an interlaced screen you'd never know.
Tony Parenti April 12th, 2007 10:24 AM
So let's say in my case my final output would be to my 1080p 37" LCD screen. I would most def. want to render 60i to 30p correct?? In your case what did you render final output to "i" or "p"?? Was it 30p??
When rendering 60i to 30p do you leave yourself open to artifacting because the program has to take the 2 fields and make one whole frame out of it??
I also noticed in your video that at some points it looks like you used a strobe effect or stutter effect. Was that done in post processing.. particularly at 7:40min - 7:50min....
Austin Meyers April 12th, 2007 10:33 AM
that is correct. in my case since the final product for this is the web, i made it Progressive. as far as artifacting i haven't noticed any using FCP's deinterlacer. there might be someone out there who knows better than me, i'm fairly new to messing with interlaced stuff as i always shot in frame mode with my previous cams so it wasn't an issue. and worse come to worst you can play progressive stuff on an interlaced tv, it just won't be as smooth as the interlaced stuff.
Austin Meyers April 12th, 2007 09:37 PM
1080 footage posted now
the 1080 stuff is posted. it's zipped and par'd.
http://file.meyersproduction.com/hv2...ddo%201080.zip
769mb
check it out.
