-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   It doesnt fit! Rode SM3 (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/90685-doesnt-fit-rode-sm3.html)
Rapo Nazarko April 4th, 2007 06:23 PM
I finally decided on the Rode NTG2 kit from B&H allong with the SM3. Guess what??? yup...the shoe mount doesn't fit! On one end of the mount that slides into the cams hotshoe, there are "nubs" that stick out. Those will not allow it to seat into the camera. Also, the area tapers inward towards the back of the camera, so allong with the nubs, it will only slide in not even a quarter the way in. I guess if I filed the nubs down, it might fit. Has anyone else tried useing a RODE mount?
Rapo
Rob Unck April 4th, 2007 08:05 PM
Another member had some advice about Rode mounts here: http://www.dvinfo.net/conf/showthread.php?t=90271
Nelson Cole April 5th, 2007 12:00 AM
Rode VideoMic?
I have the Rode VideoMic. Does anyone know if that would fit the HV20?
Roland Gatto April 5th, 2007 12:46 PM
Rapo,
I just received my SM3 today and had to file down the nubs. I did trial and error to file them as little as possible (or else the mount would be loose in the shoe).
I insert the mount so that the nub-side fits in the back of the shoe.
Worked like a charm!
Rapo Nazarko April 5th, 2007 06:35 PM
Thanks Roland,
I fugured it would work, actually a simple fix, but I have always had a complex about messing (altering) things (like filing the tabs), but I guess its the only way to use a mic huh? Does it mess with the small "Canon brand mic" contacts? The NTG2 is HUGE in this little cam, But I am sure I will enjoey the results?
Rapo
Rapo Nazarko April 5th, 2007 06:56 PM
ps - Roland,
What mic are you mounting on the cam?
Rapo
Allan Black April 5th, 2007 06:57 PM
When you start filing it down, use the trial and error method slowly.
Take some evenly off each side and whatever you do don't let the filings fall into the head of the mic. Cover it up.
Cheers.
Roland Gatto April 6th, 2007 12:38 AM
yeah, i would remove the mic from the sm3 before you start filing away.
rapo, i know what you mean about "messing" with stuff - i'm the same way. unfortunately, rode technical support was totally unfamiliar with the hv20 and the tabs on the sm3! so i took matters into my own hands, and it seems to have worked.
as far as i can tell, the contacts do not seem to be affected.
and i'm using the at822 by audio-technica.
good luck!
Larry Kamerman April 6th, 2007 09:56 AM
It does. It's what I'm using.
Elmer Lang April 6th, 2007 07:01 PM
Just curiously, how is the audio with your external mics? No motor noise, zoom noise? Is your mic balanced/unbalanced, stereo/mono?
I ask because I just got the HV20 and the audio from captured video with external mic is noiser than the internal. It's a little SONY a friend lent me.
I'm using FCP5.1.4.
I'm a bit baffled.
best,
elmer
Jeff DeMaagd April 6th, 2007 07:40 PM
I think I've seen this issue posted on a different site.
Are there good pictures of the offending nubs?
Rapo Nazarko April 6th, 2007 07:47 PM
2 Attachment(s)
Here are a few pics of the cam with the NTG-2 on board, along with a cousin.
Rapo
Elmer Lang April 8th, 2007 02:23 PM
How is the audio of the NTG-2 mic with the HV20? Getting any motor noise or zoom grunge?
best,
elmer
Jim Rog June 5th, 2007 12:00 PM
WOW that is really big on that small little cam
Yes i would also like to know how well the NTG2 works with the HV20
is the Rode VideoMic any smaller then the NTG2
Jules Ruez June 5th, 2007 12:21 PM
The stereo Videomic fits on the HV20 with no problem. Just tighten it down and you're ready to go. The furry windshield hairs MAY get into the frame but either "combing" the hairs back or changing the windshield alleviates that.
