-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   can't get kona lh to 'see' HV10..? (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/87112-cant-get-kona-lh-see-hv10.html)
Gary Barr February 21st, 2007 08:02 AM
Hi,
I think I've tried every possible config on the HV10 playout settings but my kona lh still says 'no video'. I'm going in component with some connecters (RCA-BNC male, and then a female BNC coupler to the kona BNC component inputs) Might these be the problem?
thanks.
Gary Barr February 21st, 2007 01:48 PM
is anyone using their HV10 and going into a Kona LH/e? would be grateful to know how they're doing it.
Lee Wilson February 21st, 2007 04:18 PM
Gary
I can't help you, but can I ask why you don't simply capture using firewire ?
Gary Barr February 22nd, 2007 08:46 AM
Hi Lee,
I want a workflow as similar to a DV one as possible in terms of time - so I want to bring in the HDV as DVCProHD for ease in post. I also needed the card for other analogue sources and for HD monitoring so I'm hoping to kill a few birds.
Jeff Krepner February 23rd, 2007 02:24 PM
Try connecting the camera to the monitor (using component) to see if you are getting a signal from the camera.
Yes. Then you know it's the board/software/cables/connectors/etc.
No. Then you know it's the camera or camera cable.
Gary Barr February 25th, 2007 12:29 PM
Hi,
No, the camera and cabling are all fine, I put them through my HD projector. Any other tips?
