-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   Glidecam 2000 Pro with HV10 (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/83221-glidecam-2000-pro-hv10.html)
Fergus Anderson January 5th, 2007 10:59 AM
Hi all
Just wondered if anyone has any idea if the Glidecam 2000 Pro would work with the HV10 since the HV10 is so small and light?
I have a friend who has offered me a Glidecam 2000 Pro (woo hoo!) and as I was already considering building "the $14 steadicam" though this might well be something better?
Cheers
John C. Chu January 5th, 2007 12:06 PM
I'm sure you can use it with the Glidecam...just add some weight, like a Bogen Quick Release plate.
Still, it looks strange to support a tiny pocket cam on a Glidecam...
You should look for the old Hollywood Lite VS-1 Ultralite. Might like it a lot better.
Brad Vaughan January 5th, 2007 06:52 PM
Wow, that Glidecam 2000 looks nice!
I'm gonna get one of those. I didn't know these badboys existed! The videos at Glidecam really show how much smoother the videos are using it. I always hated the bounce I was getting in my videos, now that will be a thing of the past. (eventually, need to save up some $ first)
Now I know how those steady shots while running are made.
Hey Fergus, your friend have anymore? :)
Seriously, this is great. Thanks for posting about this!
Hard decision between the GlideCam and the Hollywood Lite though. I kinda like the looks of the Hollywood better.
Ryan Kingston (Guest) January 5th, 2007 08:38 PM
I actually made a nice little steadicam out of a bunch of old Mic stands I had laying around. Ill remember to get a picture of it at one of my shoots this weekend.
Lee Wilson January 6th, 2007 12:35 AM
I also made a mic stand steady cam a while back, worked great (ish).
Here is a more recent homebuilt stedicam of mine:
http://img109.imageshack.us/my.php?image=29cg.jpg
http://img154.imageshack.us/my.php?image=12ru4.jpg
Lee
Fergus Anderson January 6th, 2007 04:34 AM
Thanks chaps
Do you have any pics of how you used the mic stand? I have a couple hanging aro9und to - one of which is pretty light.
I should get the glidecam next sat - cant wait!
Lloyd Coleman January 7th, 2007 03:42 PM
Tried it out
I just put my HV10 on my Glidecam 2000. It does balance with minimal weight on the bottom, although I have a quick release plate on the top. With the lack of mass it does not seem to be as smooth it was with my GL2, but I really like how light and easy it is to hold. I will have to play with it some more and see if I just need to practice or add more weight on the top and bottom to make it more effective. My plan is to retire my GL2 and use the HV10 on the Glidecam as a 'B' camera along with my new A1 as the primary camera. It looks to be a good combination.
Update:
I just added two weights under the quick release plate at the top and rebalanced the Glidecam. This works very well! I am excited to have a camera that is so light and easy to use for my flying shots. Now I need to get a wide angle adapter for the camera and I will be set.
Fergus Anderson January 7th, 2007 04:32 PM
Thanks for that Lloyd I will give it a go when I get hold of the glidecam
Prech Marton January 8th, 2007 01:22 AM
I also have a Glidecam 2000 with GL2, and i also plan to buy a HV10 in spring.
Maybe you can show me a steady video in HD resolution! :)
(The only thing: can you zoom slowly with the hv10? The zoom rock is so small for my finger. Even the hc1/hc3 has small zoom, but those cam have a LANC connector, and i can connect a zoom controller. unfortunatly the hv10 doesn't have lanc)
Fergus Anderson January 8th, 2007 06:31 AM
well the HV10 has a variable zoom speed function and the slowest is very slow
Jim Hardy January 8th, 2007 08:09 PM
The HV10 also comes with a wireless remote which controls zoom, and you could hold/use it in your other hand. :)
Prech Marton January 9th, 2007 01:39 AM
Yes, but in this case i cannot zoom out slowly and panning the camera on a tripod. I want a semi-professional video, and the lanc zoom controller is a good thing for this.
The other side, the hv10 has better, sharper picture than hc3. I film in nature, lowlight issue is not a factor for me.
