Looking for a handycam, need advice
I'm looking for a handycam that has the ability to use in manual mode and of course in auto mode. Also I want to be able to plug in a mic.
I have been looking at Sony, Canon, Panasonic. At first I thought the HFG10 but this is discontinued I'm researching the forums here and on line but I'm a bit lost at the moment with what is out so I'm seeking advice from any handycam users. |
Re: Looking for a handycam, need advice
Handicams are always limited in that area, usually you can control one function at the time and you need to use the lcd screen a lot instead of real physical buttons.
Will you be using the camera in a run and gun situation or is it a controlled environment? |
Hi Noa, I was just reading one of you posts, thanks for the reply. I guess I'm after a small handycam for run and gun and I think I'll have to use these in auto mode after doing a lot of research. Do you use the CX730? and if so how does this hold up in low light etc...
Cheers |
I think most high end handicams perform well in low light, I know the Canons do and so does Sony, not sure about Panasonic but I know they produce a very sharp and crisp image. If you buy one be sure to get the most expensive model, I know for Sony a bit cheaper version has a smaller sensor and has poorer low light performance.
I can only speak for the Sony cx730 I use and I have seen they improved it on audio mainly with the latest version (I think the 780) , if you just go through the topic I started about shooting with small handicams there is allready a lot of info: http://www.dvinfo.net/forum/wedding-...handicams.html |
Thanks for the info mate.
Cheers |
i have a Canon hf g25 which i had been very happy with until last week.
The image and the controls are great for a handycam. i was really pleased until last week i was using the camera as a b camera whilst filming a wedding. i had a key moment when my other camera was running out of batteries so i took the g25 to film the scene. i work as a one man band so occasionally i have to use my b cam as an a cam. it shouldn't be a problem. to my horror the key clips filmed on the g25 were corrupt in many places. i had recorded on the internal hard drive and the clips were f**ked. green digital noise, loops of 2 seconds of video,etc. i was lucky because in 3 10 minute clips i was able to salvage the key 4 mins of footage but it was sheer luck that they turned out well. a week ago i would have recommended this camera. now i'm not so sure! |
No problems here with the legria hfg25, perfect camcorder, you must have had a faulty one
I've taken it to the Canon service centre. We'll see what they say but clearly something is faulty! The problem is that when you have a major problem like that it becomes hard to regain trust in your equipment. But as I said, before this incident I was very pleased with the camcorder's performance.
After many hours of research I have found this: Sony Cyber-shot DSC-HX300.
The only thing is no audio input, I can get around this with a Zoom. For a couple of hundred $$$ this might be a go for my needs. Anyone here used one of these? |
Hi Simon,
Check out Bruce's post about his HX300. Should get any answers you're after in that thread. http://www.dvinfo.net/forum/photo-hd...ml#post1814046 Good luck with the camera hunt. Regards, Bryce |
Thanks Bryce, I'm wondering if this is a NTSC camera only as I see no mention to PAL settings here in Australia.
Yeah for sure it's not region selectable. You would be stuck with a pal or ntsc version only, no way to get both in the one camera.
Regards, Bryce |
