-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   using the Zoom H4n with the HF G10 (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/500754-using-zoom-h4n-hf-g10.html)
Federico Perale September 16th, 2011 05:26 AM
anyone doing it?
can you connect it directly to the canon, avoid the need to sync in post?
I do that with my 5D, using a special cable, as, although some people say the sound is way better taken by the Zoom than zoom>canon, I hardly hear any difference
Chip Gallo September 16th, 2011 09:50 AM
Re: using the Zoom H4n with the HF G10
You can take the output from the headphone/line jack but there are considerations. Among them, the distance between H4N and camera -- on a long run the signal can be subject to noise and the quality of the amp used in the H4N. Test it before depending on this method.
Colin Rowe September 18th, 2011 07:53 AM
Have you thought about something like a Juicedlink ? Beautifull sound, and no problems with sync. Simply plug in your shotgun and/or your radio mic. Full control over audio levels, with amazingly clear sound.
