HV Loose Part Noise or Tape Mechanism?
I just got my HV40 today. I have not used it yet, but as I took it out of the box and was turning it upside down I could hear what sounded like a loose part. My camera does not have a tape in it or the battery installed. As I continued to turn the camera rightside up and upside down I started to suspect that this sound is coming from the tape mechanism and that the parts that are making the sound are meant to move around. Can someone verify this for me? I want to make sure nothing is wrong with the camera.
Thanks, Hugh |
It is likely the image stabilization system. Saw this question a lot with the HV20. Once camera is fired up, it should not occur.
I'll bet Chris is right. This comes up a lot for folks with new Canon HV's.
Turn it on with the image stabilization on and I'll bet it will disappear. I have an HV20 and I don't even notice it anymore. If you still hear it, then you'd better think about returning the camera. Phil |
Problem Solved.
Thanks for both of your posts, Hugh |
| All times are GMT -6. The time now is 10:13 PM. |
