-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HDV modes>FCE 3.5.1 workflow ???'s (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/144935-hdv-modes-fce-3-5-1-workflow-s.html)
Jonathan Levin March 2nd, 2009 01:49 PM
Greetings.
I got for my birthday the HV30!!!!
I've read all seven pages of this thread and the info is great. Can I ask if this workflow would be correct?:
HV30 HDV30P Cinema mode (or not)
Transfer to Mac Firewire, using Final Cut Express 3.5.1 easy set-up HDV AIC 1080i60.
I this correct? There is also a 720p30 set up. Not sure when I should use that. My guess is lower resolution.
If I look at the properties of the timeline, field dominence should be at none?
Am I correct to assume the above is exactly the same if I choose to shoot straight HDV (60i) and edit in FCE 3.5.1?
OK. I don't own a single HD TV. Still have the big Sony crt. How will the above two workflows look on that set, and if you say awful, what would I need to do to make that. Is this an eport issue using Quicktime? My plan is to eventually get a HD tv. So I want to edit thinking in the future, if you will.
I'm off to buy a firewire cable....
Thanks in advance for your wisdom and knowledge.
An old fart learning new tricks.
Jonathan
