-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   premier pro cs3 HD capture HV30 (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/119864-premier-pro-cs3-hd-capture-hv30.html)
Remi Bertin April 20th, 2008 10:11 PM
Hi,
I know there's been some talk about this before and I've read a few threads about it but I can't find a solution to my problem. I have a HV30 and Premiere Pro CS3. I bought a pci firewire card that came with no drivers (no cd at all, I also checked their useless website, there was no drivers.) It says the drivers should install automatically from windows once it detects a camcorder plugged-in.
So I tried capturing HD footage from my camcorder but windows and Premiere didnt seem to detect the cam. I tried with SD footage and it worked perfectly...
Also, there is no way (i can't find one) for me to start a HD project in Premiere Pro cs3 if it doesn't detect a camcorder with HD footage.
So thats my problem; can't capture HD footage because Premiere doesn't detect my HD cam therefore won't give my HD presets to start a project.
Thanks in advance for the most likely very simple solution to my very frustrating problem.
Scotty Luther April 22nd, 2008 02:55 PM
The first thing to do, is check to see if the Firewire card is installed:
Check in Device Manager and look for
IEEE1394 Bus Host Controllers
If you do not see anything like that, then the card is not installed. I would open up the computer again, remove and reistall the card.
