-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   hdv back to HV20 (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/110757-hdv-back-hv20.html)
Aldo Visaggio December 21st, 2007 06:43 PM
hdv back to HV20
Hello
Is it possible to edit a project in hdv final cut pro and then transfer the HDV signal back to HV20? I'm tying but can't quite figure it out.
Much Thanks, Aldo
I just finished cutting an interview using the sony EX1 and Canon HV20 (as a close up) and it cut together beautifully.
Austin Meyers December 21st, 2007 11:34 PM
It is possible, but its a bit tricky dealing with the conforming process, just make sure your fcp is up to date and the camera is in Rec-record mode
Aldo Visaggio December 22nd, 2007 12:38 PM
Hi Austin
Can you explain what Rec-record mode is? Everytime I try print to tape the camera asks me to check HDV-DV. I can't figure out what setting on the camera has to be changed. If you can give me more detail it sure would be helpful.
Thanks, Aldo
