-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HDV straight to ProRes on capture (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/108181-hdv-straight-prores-capture.html)
Gene Brockhoff November 17th, 2007 11:20 AM
Here are the release notes from Apple on the FCS2 update. This will also remove the pulldown as well.
The following new Easy Setup improves HDV 1080p24 footage workflows:
HDV-Apple ProRes 422 1080p24: Use this Easy Setup to transcode HDV 1080p24 footage from the Sony HVR-V1 camcorder to the Apple ProRes 422 codec during capture.
Two new capture presets are available for you to use for capturing and transcoding HDV footage to the Apple ProRes 422 and Apple ProRes 422 (HQ) codecs:
HDV-Apple ProRes 422: Use this capture preset to transcode HDV footage to the Apple ProRes 422 codec during capture.
HDV-Apple ProRes 422 (HQ): Use this capture preset to transcode HDV footage to the Apple ProRes 422 (HQ) codec during capture.
You can also use these new capture presets to create Easy Setups for capturing and transcoding HDV footage to the Apple ProRes 422 and Apple ProRes 422 (HQ) codecs.
Christopher Witz November 17th, 2007 11:49 AM
im sorry... can you repeat that one more time?
thats good news.
ill give it a try
Ben Syverson November 17th, 2007 01:51 PM
Holy gawd. That's awesome.
Ben Syverson November 17th, 2007 08:20 PM
Hmm... I just tried this in 6.0.2, and the problem is that the Log and Capture window no longer comes up. When I go to Log and Capture, a window pops up asking me to name a file... If I enter a filename, it starts playing the tape and capturing immediately.
So it might not be fully baked yet...
