-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   HV20 - cannot do END SEARCH (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/102418-hv20-cannot-do-end-search.html)
Slava Barouline August 29th, 2007 10:08 AM
Hi
I would like to do end search on my tape during playback.
It used to work before, but now this menu item is disabled in the menu and I cannot select it.
What am I missing?
Slava
Andrew Plumb August 29th, 2007 10:24 AM
Have you ejected the tape at all since recording the material?
Slava Barouline August 29th, 2007 06:06 PM
Yes, I have
Does it work only if tape is never ejected?
Strange
Andrew Plumb August 29th, 2007 10:19 PM
Alas, that is how it works. (See the Notes on pg. 32 of the HV20 NTSC manual)
Once you've manually found the end though, as you append more recordings after it, the camera will remember the new end until the next time you eject the tape.
Slava Barouline August 30th, 2007 04:45 AM
Indeed
Page 30 in PAL manual
Steve MacDonald August 31st, 2007 09:12 AM
The alternative is to buy DV tapes that have memory chips which will allow you to an end search regardless of having ejected the tape.
Chris Hurd August 31st, 2007 09:14 AM
Originally Posted by Steve MacDonald (Post 737421)
DV tapes that have memory chips...
Canon camcorders can't read that chip. Only certain Sony camcorders can make use of it.
Steve MacDonald August 31st, 2007 02:21 PM
Oh no, I was told differently. lesson learned, test it before you post it.
My bad, I apologize.
