-   Canon VIXIA Series AVCHD and HDV Camcorders (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/)
-   -   UPDATED: CINEMODE HV20 softness (https://www.dvinfo.net/forum/canon-vixia-series-avchd-hdv-camcorders/101086-updated-cinemode-hv20-softness.html)
Eki Halkka August 14th, 2007 06:22 PM
Originally Posted by Chris Barcellos (Post 729016)
Not if you are using a 35mm adapter....
In that case, if you already have enough, the additional light won't affect the resulting image in one way or another.
You add light - and then adjust camera's exposure to darken image... the result is the same.
Ian G. Thompson August 14th, 2007 06:23 PM
Originally Posted by Eugenia Loli-Queru (Post 729000)
Right. And how much enough is enough for each scene? Without a light professional on location you will never know. Indie filmmakers try to do a lot of things by themselves, but light and sound are two "beasts" that it's very difficult to get them right.
If that's what it takes to get the right picture then it just forces us to become better filmakers. I want to know how to manipulate light better to get the shot I need. I am greatful that they put this feature in this "consumer" cam.
Ian G. Thompson August 14th, 2007 06:28 PM
Originally Posted by Eki Halkka (Post 729004)
Umh?? Enough light to get the image you want without using gain. Enough for the current shot.
BTW, If the goal is to get as "filmic" images as possible, usually one gets *best* results (with video cameras, especially small ones like HV20) using as little light as possible - the reason for this is to get as open aperture as possible, for shallow depth of field...
Wouldn't this just add gain to the picture which increases grain? I would think you need as much light as possible but then start using ND filters to control the incoming light.
Eki Halkka August 14th, 2007 06:29 PM
This is a good place to start:
http://www.efplighting.com/
Eki Halkka August 14th, 2007 06:33 PM
As little as possible to get correct exposure / the image you're after without using gain. In some cases, it might be truckloads, in others just a 40W light bulb.
If you add a lot of light and then use ND the result is exactly the same as using less light in the first place.
***note: when i talk about "more light" and "less light" i talk only about the intensity of the light in a technical sense, not i.e. the amount of light sources***
Ian G. Thompson August 14th, 2007 06:40 PM
Thanks.it was really more rhetorical in nature...but good info anyways.
Salah Baker August 14th, 2007 07:06 PM
Just for the hell of it.
Have a Pre-release psd to keep interest up.
I’m going on Vacation; Stu has files, settings, and cam info....
http://www.salatar.com/hv20chart/hatediscontent.psd
the name of psd should give you my slant on it.
Joseph H. Moore August 14th, 2007 07:12 PM
Salah,
Those green and red circles are things of beauty. A Blackmagic Design Intensity capture station is in my future!
Joseph H. Moore August 14th, 2007 07:16 PM
btw, Salah, did you notice the BRIGHTNESS control doing anything?
Bruno Donnet August 15th, 2007 02:20 AM
Originally Posted by Joseph H. Moore (Post 728869)
Here's the new set-up. It's got a little bit of everything in it, strong highlights, rich shadows, subtle textures, bold colors, subtle colors, etc.
I shot every different custom image setting through -1,0,+1 in both Tv and CINE mode.
Great job, Joseph.
Wait impatiently for the publishing of your results on your web site at the end of this week.
I feel now a little guilty to have push you. Hope you don't feel offended ;)
Joseph H. Moore August 15th, 2007 06:10 AM
Bruno,
It's already done. You can download it here:
http://files-upload.com/files/434996...20Life.psd.zip
You will need Photoshop, or another application that can read layered PSD files.
Bruno Donnet August 15th, 2007 08:35 AM
Link unusable (you have copied it as short text with its '...' inside instead of the corresponding long path text)
Joseph H. Moore August 15th, 2007 08:37 AM
Fixed. It's also linked on page 2, btw.
Salah Baker August 26th, 2007 01:10 PM
http://www.salatar.com/hv20chart/charttest2.psd
guess Stu is to busy
Joseph H. Moore August 26th, 2007 03:31 PM
Thanks for posting those, Salah. Did you happen to record to tape, as well. It would be interesting to compare of just one of the settings with the same shot after HDV compression.
