Title Mix function DOES WORK!!!
I finally figured out how to get the title mix function to add a title,logo,bug,letterbox black bars, etc..
HERE IS HOW.... open a new photoshop image (or whatever you use) make sure its 640 x 480 px. this camera uses a Luminance Key to overlay images.... so.... create whatever image you want, if you want to use BLACK in your image, make sure you use these RGB settings.. R=12 G=12 B=12. now when you have the image that you want, add a new layer (background) make sure that it is BLACK (R=0 G=0 B=0). This is the most important part. Save the image as Jpeg. But save it to the TITLES folder on the SD/MMC Card, and save it as this filename USR00001.jpeg. then USR00002 and so on. after you save it to the card, switch the cam to tape/camera. From the menu, select Title Mix/Select title. There you go!! Tustin Video/Multimedia Guy City of Cathedral City |
Outstanding. Many thanks, Tustin... I knew there had to be a way. Hats off to you!
Thank you very much!
We've been trying several times, but finally here's someone with the solution. Great work!! |
Amazing!
Thanks Tustin. Yes this does work, with one very minor correction, the file extension needs to be .JPG
You've saved the day, and found a solution to what I considered to be a major Canon faux pas. Chris, I think this is worthy of Watchdog Report or Resource status. And on Tustin's 1st post... (So how do we clue in Canon Tech Support that this IS possible?) Mic |
stay tuned...
Hello,
Thank you for the comments. I didn't believe that it couldn't be done, So, I was bored a few nights ago and sat down and worked it out. I will be writing an article about the title mix function.(complete with detailed images) And..... Chris has agreed to publish it on the Son of Watchdog GL2 page. I will work on it tonight, so it will available soon. Thanx, Tustin Larson |
| All times are GMT -6. The time now is 06:32 AM. |
