-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Has the GL2 Forum died? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/485867-has-gl2-forum-died.html)
David Ruhland October 9th, 2010 06:27 AM
Its been awhile since I have visited the site, but i was kinda sad to see the last post in the GL forum was weeks ago. Although I have also upgraded my cameras to HDV and SD...I still find the quality of theGL video astonishing. Most my stuff is for web so my GL2 works great esp when rendered at a high bit rate.
Chris Hurd October 9th, 2010 07:43 AM
As long as Canon USA lists the GL2 as a current product,
this forum will remain open. That camcorder has had the
most enduring longevity of any model in the market.
Tom Dickerson October 9th, 2010 08:01 AM
It's kind of funny...I sold both of me GL2's to buy a Panisonic HMC40 a few months ago. I kind of miss them. Most of my stuff is for DVD or web. I found the GL's quick and simple to use - and edit.
In my opinion, I don't think we see a lot on here because they are so easy to use - and seldom give a person any trouble. For me, they were real, solid, work horses.
No doubt about it, they are great cameras.
Don Palomaki October 9th, 2010 04:16 PM
Also, folks with GL-specific question can probably find the answer using search faster that waiting for a reply. And today's GL users are likely serious users, not newbes in need of hand holding. Most of those folks are probably buying the new AVCHD machines.
Jeremiah Rickert October 17th, 2010 12:03 AM
I'd like to note, that I still use my GL1 as a deck for DV projects, and as a fourth camera occasionally. Still works. No dead pixels...no scratches on the glass.
The only problem is that the LCD screen only works when it's flipped forward or pinned to the side facing out. :)
Still, pretty good mileage.
Kyle Root October 17th, 2010 07:02 PM
The forum may not be dead, but my original GL1 power supply/charger died Saturday morning (right before a wedding shoot) after having served me quite well for 11 years. It was starting to show signs of major wear though, as the camera charger part would barely stay plugged into the charger itself.
Fortunately, it and my XL1s charger are interchangeable!
Tom Blizzard November 24th, 2010 08:13 PM
Interesting........ I was shooting my GL1 along with 2 GL2 cams at a wedding in Texas and the GL1 fell from the tripod, don't ask, and fell from a second floor balcony to the wood floor below. Hit on the 3 hour Canon battery. After the initial hit, the battery fell off and the bayonet mount 16:9 anamorphic lens popped off..... The battery must have taken a major part of the shock............... because....
I picked up the GL1, put the lens back on, put in a new 1 hour battery, and to my surprise it still worked!!! Captured the footage and it is now part of the wedding video.
Michael Connor March 6th, 2011 01:22 PM
Re: Has the GL2 Forum died?
excellent! im still using.. and just got a 2nd. Cant wait to get filming.. im now hunting for peoples tips on 2 camera shooting and .. chromakey settings.. and trying to sus out what exactly hd upscaling software does my heed is battered!
I just know hd has more pixels/ lines.. where as these sd cams have less.. BUT.. avi files contain more info than needed.. so theroetically an upscaled HD from an sd GM2 cam should look be better than SD footage that has not been upscaled?!?
Don Palomaki March 12th, 2011 07:47 AM
An upscaled SD image contains no additional real information, just what ever interpolations and artifacts the scaling software adds. These may be acceptable, even pleasing, or they bomb. It all depends on the quality of the scaling, the original footage, the ultimate viewing system, and the viewers expectations.
If the intent is to produce an HD end product you are generally better off using a HD (or HDV) camera.
Recommend you run some tests with your gear and typical client viewing systems to see what works and fits into your work flow.
