-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Ultra Slow Zoom (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/30811-ultra-slow-zoom.html)
Ron Edwards August 21st, 2004 05:20 PM
Ultra Slow Zoom
I have set the GL-2 at different speeds for the zoom and those settings seem to be working as designed ... but I would like for the zoom to be much slower yet. Anyone know a way to get a very sloooooooooow zoom?
Boyd Ostroff August 21st, 2004 06:03 PM
I'm not familiar with the GL-2, but you may need a LANC zoom controller to accomplish this, or at least that seems to be the case on my Sony cameras. I ended up getting a Varizoom Pro-L because it has a dial which lets you choose the absolute minimum zoom speed allowed by your camera. I'm sure there are other controllers with a similar feature as well.
However, this still may not do what you want. The zoom speed is limited by the capability of the servo motor in the camera. You will also probably notice a bit of a jolt when the zoom starts, since that's just how most of our prosumer cameras are built.
I'm sure someone else with specific GL-2 experience will have some specific input on this.
Ken Tanaka August 21st, 2004 11:43 PM
Boyd is quite correct. The main rocker on the GL-2 can access the full range of its zoom speeds. But the range of speeds is limited to, I believe, 4-5 speeds. A LANC controller may make it easier for you to run the slowest speed, particularly the controllers that feature a separate speed dial (such as Varizoom's Pro-L controller).
But the GL-2's zoom servo motor, like those of the lenses on all of its peers, is not the same as is found on broadcast lenses. In particular, they have only stepped motion curves.
To accomplish a completely smooth "zoom" don't use the zoom at all. Use a very smooth dolly, such as a wheelchair.
Alan McCormick August 22nd, 2004 01:19 AM
The ZR1000 provides those presets and the slowest zoom is OK for what I do, a lot better than the standard Cam zoom. I suggest you try some out if you can before buying.
Graham Bernard August 22nd, 2004 02:22 AM
Jerky Snatch!
Alan is correct. But, there is a "snatch" at the beginning of the zoom - no matter how careful you are and you will be anticipating this "jerk" and not be thinking about the shot! . . . The effect of this is that from STILL to MOVE can be quite different in the "feel" of that beautiful zoom your are trying to accomplish. Solution: Take account of this and "design" your zoom "take" so that you have a short "lead-in" wasteage to the actual zoom. This you can then remove/dissolve-over on the timeline - get it?
Grazie
Alan McCormick August 22nd, 2004 01:56 PM
Grazie,
I will have to look a lot closer because I did not see "the snatch" as you call it.
Maybe it is those experienced eyes of yours again striving for perfection (I am 1yr behind you but still have the same aim).
Ron Edwards August 22nd, 2004 02:57 PM
Hey guys ... great ideas. Edit the "start-up of the zoom" and move the entire camera are both very good! Not able to test any controllers here ... out in the middle of 1M acres of corn....ha. Any other ideas out there?
