-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   gl1 wireless mic audio problems (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/28241-gl1-wireless-mic-audio-problems.html)
Dan Heaton June 29th, 2004 05:36 PM
Hi,
Is there any way to control the level of the audio coming into the gl1 from a wireless mic with no audio controls? Any time I have attached a wireless mic to my Gl1 and used it for an interview the sound has come out extremely quiet. How can I boost the sound?
K. Forman June 29th, 2004 05:50 PM
Turn off the mic att, I bet that is your problem ;)
Dan Heaton June 29th, 2004 05:52 PM
Hi,
Thanks for the reply, but I am a bit confused...
Turn off the mic attachment when I am using a mic attachment (the wireless mic)?
K. Forman June 29th, 2004 06:11 PM
Yes- It is in your menu. I have the same problem when using my shotgun.
Dan Heaton June 29th, 2004 06:26 PM
Thanks Keith,
What type of wireless mic do you own... how does it work with the Gl1?
K. Forman June 29th, 2004 06:53 PM
I have the Azden WR22 wireless lavs, and they work great. Mostly use the AT55 shotgun though.
Don Palomaki June 30th, 2004 04:49 AM
MIC Attenuator. Cuts the input level from the external mic by about 20 dB.
