-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Did I screw up? (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/27991-did-i-screw-up.html)
Joe Cirino June 23rd, 2004 10:06 PM
Did I screw up?
Well, not really thinking, I shot a powerboat race a week ago and took off my external mic and forgot to sock my GL2 mic. Did I screw it up? I had the camera in at least a 50mph head wind. I have yet to capture the video to see if the audio is shot on the mic. I am guessing that I probably damage the cone in the mic???
Do you think I did? Thanks
Graham Bernard June 23rd, 2004 11:27 PM
If I was you, I would be doing some sound checks right now. Why are you waiting? Do you have the camera to to do this with? Why wait till you capture - "I have yet to capture the video to see if the audio is shot on the mic."? This I really don't understand .. Why don't you record something else now and and stick on a set of headphones to check levels? Why are you worrying about something that you aren't - YET - in a position to hear what you've recorded .. don't understand . .
Regards,
Grazie
Joe Cirino June 23rd, 2004 11:59 PM
I guess if I had the ability to check for damage I would of never posted.
Well, first, I have been VERY busy writing papers for graduate work. And second, the camera is in the shop for a head cleaning.
"Why are you worrying about something that you aren't - YET - in a position to hear what you've recorded .. don't understand . . "
I was looking for either:
1. Yea, you screwed up mics can't blah blah blah
2. It should be fine because blah blah blah
Now that the confusion if cleared up, can a onboard mic get damaged in head on winds?
Graham Bernard June 24th, 2004 12:11 AM
Understood . . good luck with the, "writing papers for graduate work" . .
Grazie
Robin Davies-Rollinson June 24th, 2004 12:15 AM
I wouldn't have though so - they are quite tiny and hidden behind the outer grill. The wind should have been largely dissipated by the time it reached them...
Robin.
Alan Craven June 25th, 2004 12:14 AM
The prurpose of a windsock is to reduce unwanted audible effects from the wind in the recorded sound, not to protect the microphone capsule from damage.
I have always found the results to be very little better with a Rycote gag in place than without in any wind. Having said that, even the best microphone/gag combination will struggle in strong winds.
You may have a problem with the recorded sound quality here.
Joe Cirino June 25th, 2004 07:08 AM
Bad sound quality I can live with. So chances are my mic is ok. Cool. I'll know in about a day.
