Compatability of GL-2's w/ cannon Vixia HV-30??
My wife and I use 2 Cannon GL-2's for our wedding & event videography, we also use a
third camera ( Sony 1 chipper) at the back of the sanctuary for a wide shot and to cut back to when the need arises.We are concidering buying a Cannon Vixia HV-30 to replace the sony, instead of buying another GL-2 (cost reasons). Will this be a logical choice?? I know the editing will envolve mixing SD DV w/ HD DV. and will the footage of cameras be too different?? We edit on Sony Vegas 8.0c Thanks for Your responses! Blayde @ Cornerstone |
Vixia will shoot SD, either 4.3 or 16:9, or you can capture HDV in Vegas, and down rez in post. I mix this camera (actually HV20) with my Sony cameras footage (FX1 and VX2000) with good results. You will need to try to match things, even in post, but the HV30 does have an array of adjustments that can get you close.
Thanks Chris,
We will take your info and run with it!! Blayde & Lori @ Cornerstone |
| All times are GMT -6. The time now is 11:16 AM. |
