Help With Depth of Field on GL2...
Hi All,
I have recently purchased a GL2 and having trouble getting a proper DOF shot. I have a talent at the front and a talent in the background. I'd like to move focus from the subject in the background to the subject in the front and vice versa. This vid has acheived it nicely without any other equipment: http://www.youtube.com/watch?v=UXbTo6b_bxs Can someone please guide me step by step on how I can acheive this effect? Thanks so much in advance. |
It is tough with video but the best thing you can do is move the camera back as far as possible and zoom in all the way. Open the iris up as far as it will go. You might need to use the ND filter to keep the shutter speed at 1/60.
Use Manual Focus to change the focus from front to back. It takes practice. |
Also you may have to "over focus" a bit; i.e., focus a bit past the far subject and in front of the near subject so each is just barely within the DOF range for their distance and the other is out of it.
Sadly, the G2 does not have witness marks on the lense -- but then, why would it? That abomination servo focus defeats the possibility of using them. However, get yourself a roll of white paper tape (aka, artist tape... NOT masking tape!) and wrap some around the focus ring and the lens barrel in order to give you a place to add some reference markers for whoever will do the focus pulling. |
the technical answers above are all correct, I believe, but just for the dummies (like me) reading this, here's the non-technical answer... (I think)
Low F numbers - F1.8, F2 Maximum zoom will produce the smallest depth of field. Anything different will make the DOF larger, but you still might find it's good enough for you. good luck! |
If you want to spend some more money (~$1000), consider the LETUS product as a way to obtain 35mm film-like DOF with a video camera using 35mm still lenses. see: http://www.letusdirect.com/
Search the forums for "LETUS" for comments by others on this product. And there ares some instructions around on the web for do-it-yourself versions that will cost as little as $15 in materials if you have a reasonable amount of spare/junk stuff around the house and are handy. |
