-   Canon GL Series DV Camcorders (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/)
-   -   Rewinding, soft cases and more (https://www.dvinfo.net/forum/canon-gl-series-dv-camcorders/115342-rewinding-soft-cases-more.html)
AB&GDigital October 15th, 2001 09:06 AM
rewinding
When tape is run to end it sometimes won't rewind,instead we get an eject tape message. Sometimes removing tape and reinserting it works, but not always. Then we have to rewind in another camcorder. Any thoughts or suggestions appreciated. Mator
Hans Kuipers October 13th, 2002 08:56 AM
dead/hot pixcel
How can I test in a shop if the camcorder I want to buy is free from dead/hot pixcels on the CCD, LCD screen and the EVF??
Ken Tanaka October 13th, 2002 12:38 PM
Point the camera at a flat colored surface (not strictly black or white) and inspect the vf and lcd images to see if a pixel appears odd-colored. Dead is often red on lcd's, and the vf is also a lcd-type display. Then shoot 10 secs or so of footage at the same target and playback on a full-frame pro monitor or computer to check for odd pixels.
Michael Pappas October 13th, 2002 02:12 PM
Testing:
Put the cap on the camera. Gain up to 18db. Set shutter speed to 1/8th a second.
Viewing:
Set monitor brightness to full bright so the blacks levels are washed. This way you see the full extent of the image.
If your using the LCD 2.5 screen Turn the brightness setting to full. Clear all data on screen.
Michael Pappas
Bill Hardy December 30th, 2002 07:17 PM
GL2 At Islands Of Adventure
Went to Universal Studios theme park a few days before Christmas. I am downloading some stills now but the web page is up. You can check out the frame mode stills at
http://homepage.mac.com/bhardy3/PhotoAlbum33.html
Enjoy, more stills to come. It was raining on and off so I did not make a lot of adjustments, plus my party was always moving.
Tim Palmer-Benson December 31st, 2002 04:53 PM
Recommended back pack for GL2?
I want to use my GL2 on the ski slopes and out x-country skiing and biking. What would you people recommend as a backpack that would withstand a fall! I also plan to pack a tripod because all my shooting will be for the web and I must have a relatively still background to get the best compression.
Tb
Alex Ratson January 1st, 2003 03:58 PM
I would recommend a LowePro DryZone 200. Its fairly water tight, and has a spot to stick your tripod.
You can get some more info on the bag u can check it out at: http://www.lowepro.com/pages/series/dryzone/dzone.htm
Alex
Chris Hurd January 1st, 2003 04:28 PM
See also the CCC - 3333 Multi-Purpose Soft Case from KATA, perfect for the GL2, at http://www.dvinfo.net/canon/articles/article81.php
