-   Canon EOS Full Frame for HD (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/)
-   -   ND Filters - aaargh! (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/528647-nd-filters-aaargh.html)
Peter Rush June 5th, 2015 03:06 AM
OK so I've just bought a Genustech variable ND to use with my 24-105mm EF lens - problem is I can't put it on or take it off with the lens hood attached, and if I take the hood off to put the filter on then the lens hood will not fit over the filter!
Anyone else come across this and come up with a workaround?
Bruce Phung June 5th, 2015 08:57 AM
Re: ND Filters - aaargh!
Can't use hood with ND Filter. Beside, you would not want a hood any way because you will need to rotate the ring to get desired light.
Ger Griffin June 6th, 2015 04:53 PM
Eclipse ND Fader 77mm Variable ND Filter - Genustech
Theres an optional hood available or maybe use any cheap 82 mm hood (might work)
Warren Kawamoto July 15th, 2015 10:40 AM
I have a cheap, collapsible rubber lens hood on top of my ND filter like this:
