Anyone transcoding footage?
Hi all - footage from my 5D3 is very choppy on the timeline (prem pro CS5.5) and occasionally, when rendering out it falls over when encountering 5D clips - not always though which is baffling. It's now driving me nuts and I want a solution before I get busy again with weddings this year.
I'm wondering if anyone has similar problems and how you get around them - can you recommend any transcoding solutions. AVCHD footage and XAVC-S from my other cams play smoothly without any problems. Pete |
Re: Anyone transcoding footage?
Hi Pete. I hope more expert people come in, but I'll ask some questions that may she'd some light.
Are the clips from your 5D on an SSD drive? Are you using All-I compression? Which effects are you applying to the clips? Have you tried editing on another editor to see if the problem occurs there? What is your OS and computer specs? |
changed my mind on this one.
Chris I'm using IPB compression. The clips are on a standard 7,200 speed hard drive (not SSD) and on the timeline they have no effects. Clips play smooth only for a couple of seconds and then get choppy.
Intel i7 processor 3.40/ghz, Windows 7, 16GB Ram, 1.5GB Nvidia CUDA card - it's a pretty decent setup. Pete |
It's definitely a codec issue then. Either upgrade to cs6 or transcode. I haven't tried it, but many recommend DNxHD from Avid.
UPDATE: Here is one program that I've used in the past for transcoding: http://www.squared5.com/svideo/mpeg-streamclip-win.html |
Cheers guys :)
| All times are GMT -6. The time now is 12:19 PM. |
