Bridge plates, rails and mounting ultra-telephotos
Hi List,
Looking for some ideas please. I need to come up with a robust mount solution to allow me to mount ultra-telephotos (800mm etc) on rails primarily with EOS bodies, but ultimately with any cinema camera. The primary reason being additional stability (shooting 4k) + sliding adjustment for tripod balance. With bare lens / EOS I can normally get balance using the lens foot, but adding mattebox, EVF and alternative power soultions is going to change this. I'm expecting to end up using an Arri-type base plate or similar, but how to (affordably) affix rails to this, with plenty of adjustment back and forwards? Thoughts appreciated. Nick. |
Re: Bridge plates, rails and mounting ultra-telephotos
I mount an extended Arri dovetail along with bridge plate to my OConnor 1030D head which allows balancing of the camera and lens. I can then use 15mm or 19mm rails as needed.
Thanks David,
Yes, I think the Arri or variations thereof is the answer (and I have a 1030D), the question is one or multiple bridge plates and then the question of height adjustments between them? It looks like Alan has had similar issues here with his FS700 http://www.dvinfo.net/forum/under-wa...ve-review.html |
I have a few different risers depending on he camera I use.
I'm trying to remember, but I think it was David Winters that had a coupe of aluminum dovetails machined with camera riser built in. I'll try to dig up a link. http://dpwinters.com/products/ |
Thank you David, some very helpful information on David Winters' site - I'll make contact and perhaps look into having something machined here, it looks less complex than I feared.
Best, Nick |
Nick, let me know what you come up with. I'm always looking for a better way.
Dave |
I use Arri style dovetails from Wooden Camera
2060/2575/120EX Dovetail (18) - ARRI Style Dovetail Either use a dovetail clamp on the lens feet and mount it with the camera hanging on the back Dovetail Clamp - Mini Bridgeplate or use rails with a bridge plate. Bridgeplate (19mm) There are many options, you need to search to suit your own preferences. You can also use this from Really right stuff. This is a photography styled lens support: Kennan Ward Super-Tele Package - KennanWardPkg - Kit Configuration Page |
| All times are GMT -6. The time now is 04:40 AM. |
