Camcorder equal to the 5D quality?
I love my 5D MKII but I hate my Canon XH A1s, it's horrible in low light and very grainy. I shoot a lot of MMA training for UFC and other outlets and I need a good quality camcorder with the image quality of the 5D but Live auto focus. Nearly impossible to film MMA training with manual focus. Anybody have any HD Camcorder suggestions in the same price range as the 5D???
Thanks much. |
Re: Camcorder equal to the 5D quality?
2nd hand EX1
The closest I can come up with is the Sony NEX-VG900 at close to $3,200. Next in line I'd name the Canon C100, but that sells for a bit more, around $6,500
Both should have great low-light performance, with the VG900 having a fullframe sensor like the 5D, and the C100 a close to APS-C sensorsize like the 7D (but with fysically bigger pixels, ergo more light-sensitive) ... but the live auto focus might be a bit tricky here, sorry. |
In my opinion, you can purchase the Canon XF G10 or the XF G20 and get probably better low light performance than what you have on the 5D Mark III. I have both the 5D Mark III and the older XF G10 and I don't have any issues. If the low light shooting wasn't an issue, I would suggest the Canon XLH1. That cam is still a beast and will be for some time. If you go with the Sony (I like the Sony) the colors will be more of a problem to match than the Canon products based on what I have read. Good luck!
I was just looking at the Sony HXR-NX70, youtube low light tests look pretty good. Thoughs? |
http://www.bhphotovideo.com/c/product/884602-REG/Sony_PMW_200_XDCAM_HD422_Camcorder.html |
In the end, if you have the resources to rent all of the cameras mentioned throughout your post, it would probably help you to make the best decision based on your personal needs. Good Luck |
Danny I guess it might depend how low the lighting is and how you are filming, let me try and explain. Also bear in mind this is just my opinion and is not a scientific evaluation in any way shape or form.
I own the XF300, XF100 and 1Dx DSLR. The 1Dx is the best in very low light by MILES in my opinion. I have tested all the cameras listed in my kitchen at night but with the normal lighting you would expect in a kitchen, in other words not sunlight but certainly not extreme low light. In every test the 1Dx blew the others away for noise. The XF300 is ok(ish) if you keep the gain below about 6db but with the lighting I had 6db ended up being pretty under exposed so not really that usable. The XF100 is worse than the XF300 but not by miles really. Certainly not as much of a difference as there is between the 1Dx and XF300. When I tested it shooting a wide shot of the whole room the noise was there but you could live with it. It's when you zoom right in and get a shallower depth of field that the noise on the XF cameras really shows. It's the out of focus bits that become very noticeable noisy. Based on this I would advise renting,borrowing or just testing in a shop if you think either of the XF cameras might be the one for you. I'm not saying they are rubbish in low light but for ME and MY needs they are too noisy really. I am looking to buy a C300 because it's a bit better than the 1Dx in low light but way more usable than the 1Dx (things like peaking, audio inputs etc etc). Hope that's useful for you and I say once again this is just my own judgement and opinion based purely on my own uses and needs. |
Andy,
I've been thinking about getting the 1DX for both photography and videography. With that being said, I do have the 5D Mark III. Is there a significance difference on the video side moving up to the 1Dx or should I go for the C100? The C300, for now, is out of my budget, as I am not that big and yet. |
Thanks for the great info Andy, I guess I probably left out some important details. 1, the gym I shoot in (Jacksons MMA) is very dark, dark grey walls and black ceiling. I Have decent dayflo lights but not nearly enought to light the whole gym up. 2, Since it's MMA Action, I would love to speed my shutter up to at least 1/100 to prevent motion blur, can't do that with my XH A1s with gain set to low, have to shoot at 1/30th becasue of the low light. I never use medium or high gain because of all the noise and grain of course, even with all my custom presets optimized. 3, MUST HAVE LIVE AUTO FOCUS. 4, I am very good at color correcting mediocre footage, the problem is that some of the orginizations I shoot for want the raw un CC'd footage, ugh, so hard to send when it's not perfect. So what I need is most likely not in my budget unfortunately, guess I'll just have to do more spec work and earn enough money to be able to afford what I really need. Thanks again! |
If video was the main objective I would certainly be looking at the C100/300 because I find shooting video with a DSLR doable but not ideal. Audio needs to be recorded separately, no peaking, zebra, the C300 is much much better to hold in the hand if you are not using a tripod. I guess it really depends what you plan on doing with it. I'd say if you want stills as well as video go for a 5DmkIII and spend the extra on some glass rather than going for a 1Dx but if you do video mainly I'd go for a C100. As always though I'd recommend at least going to a shop and having a play with each of them. |
It seems to me that we need different tools for particular applications from a video gathering viewpoint nowadays. I use an XF300, Canon 1DMK4, and Canon G1X compact, and I'd hate to be without any one of them. The XF300 gets by far the most use, but the 1DMK4 has much better low light capabilities and can do reasonable DoF, and the G1X is small and light and convenient. I often keep the G1X on my shoulder, while using the XF300 on a tripod, so I can grab b-roll on the fly.
