-   Canon EOS Full Frame for HD (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/)
-   -   Thin Variable ND 82mm (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/511241-thin-variable-nd-82mm.html)
Chas Isenhart October 8th, 2012 12:18 PM
What is the thinnest variable ND in 82mm?
The Singh-Ray 'thin mount' sounds like it has lower profile specs, but before I buy I'd love to hear if anyone has gone through and tested wider lens vignetting on the various brands of variable NDs. Shooting a Mark3 with a 16-35mm.
The regular profile Singh-Ray that I rented started to vignette at about 26mm and below.
Chas Isenhart
Scott Stoneback October 13th, 2012 11:43 PM
Re: Thin Variable ND 82mm
I've got a Light Works variND and I really like it. It is on my 24-105 L lens and 35mm Rokinon lens. No vignetting unless you stack it on top of a UV Haze filter. Even then, it is very minor. They get around the vignetting by essentially stepping down the filter... so you end up with a slightly larger front piece of glass that won't fit the 77mm lens hood very well.
