-   Canon EOS Full Frame for HD (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/)
-   -   anyone using the Manfrotto 561 BHDV monopod? (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/498316-anyone-using-manfrotto-561-bhdv-monopod.html)
Peter Riding July 16th, 2011 04:29 PM
Re: anyone using the Manfrotto 561 BHDV monopod?
I'm going to be a dissenting voice here.
For a long time I've used the Gitzo GM5561T Mountaineer monopod. Its far more expensive than the manfrotto and does not come with a head, but its very light, very chunky so easy to hold, and collapses very short so is easy to carry even on your belt. You can use it totally collapsed and steadied against your waist with good results.
Gitzo GM5561T Mountaineer Monopod - Carbon Fibre
I've been using it with a Manfrotto 701HDV video head. The head is great for what it is.
Manfrotto 701HDV Pro Fluid Mini Head - Fluid
Previously I'd used a smaller head, the manfrotto 234RC, but switched to the 701 in order to be able to use the same quick release plates on all my gear.
Manfrotto 234RC QR Monopod Tilt Head - Tilt Tops Accessories
However, who uses the head to pan and tilt rather than just rotating the monopod itself? Its no more stable to use a head on a monopod.
I'm sure many videographers don't realise that you can get an adapter that fixes direct to the monopod and allows you to use the normal standard 501Pl plate which many of us use as standard on all our gear. Its the Manfrotto 577:
Manfrotto 577 Sliding Plate Adaptor - Quick Releases Plates
Just screw that onto your monopod and you're good to go :-)
The Manfrotto video monopods have small retractable feet ..... but so what. They are not substantial enough to risk leaving a cam atop unattended. You might just as well use a normal monopod and for situations where you want a quick and stable platform without the bulk of a tripod just put a 701HDV on top of a normal lightstand. Lightstands also give you a LOT more height than tripods :-)
Pete
Harry Simpson July 18th, 2011 08:03 AM
That's what I figured cause when i opened it up i knew that wasn't right....may give this one another shot.
Harry Simpson July 18th, 2011 02:25 PM
Welp this has been a great thread!! I've ordered this monopod today - it'll be here Wed and I have a shoot Friday.
Question: Anyone attaching a small 7" monitor to this monopod is some fashion.....i'm gonna try it but wondered how anyone else's mileage varied doing this.....
Jeff Murray July 20th, 2011 11:08 AM
Only comment I'd make over that lovely light Gitzo monopod is the Manfrotto has the 3 feet. You can actually support the camera with a small light lens on it (not unattended). But it allows you to try out an HDR or long exposure. Even like this there will be some lateral movement (wind, mirror, lock-up, etc) but the 'align images' setting in most editing software will fix this.
However faced with lugging my 3.5kg tripod up a Scottish Mountain - I prefer the monopod anyday.
Guy Cochran July 26th, 2011 04:28 PM
I use a Manfrotto Superclamp with an IKAN Israeli arm to attach my 7" monitor to the monopod.
These 561B HDV-1 monopods have been getting really popular. We can hardly keep them in stock. Stillmotion just produced a video worth watching
Federico Perale July 26th, 2011 05:20 PM
very nice video indeed
still...I am not convinced people should be invited to try the "static" method, of leaving the camera unattended on the monopod...
a small hint of wind and.....BLAAAAAM
Harry Simpson July 26th, 2011 09:31 PM
Ordered the Cinevate Simplis and articulating arm - after the shoot friday i decided i def needed the monitor for focus accuracy!
Greg Fiske July 27th, 2011 09:15 AM
I have both a photo monopod and a 561 BHDV. The normal photo monopods are not great with video. They stutter when you do a pan.
My solution to using a monitor on the monopod is to use a long adapter plate. The camera screws in the front of the adapter plate, and its long enough for a dp6 to screw in the back part of the adapter plate. I've tried putting the dp6 on the hot shoe, but it creates wobble. It basically places the monitor behind the lcd and gives you enough room to make changes with the buttons.
