Tokina 11-16mm f2.8
Can i use Tokina 11-16mm f2.8 with my Canon 5D mark II?
i heard it will give problems since 5D has a full frame sensor, and Tokina comes with a ACS sensor? i'm really confused, i don;t want to end up buying the wrong lens for my 5D. i like to bye Tokina coz of its ultra wide angle capabilities. |
Ansab,
The Tokina does not come with a sensor but is made for the APS-C sized sensors like the 7D so it will not work on the larger sized sensor of the 5D MkII. I don't think Tokina makes a lense to fit the 5D MkII. |
This lens is made for APSC sized sensor, like 7D, 60d, T2i, When used on these bodies, you get an equivalent field of view of 17- 25mm. On the 5d, you have much better options for wide angles; the 17-40, the 16-35, the fabulous 14mm...
Can you recommended a stylized ultra lens for 5D other than Tokina? Thanks
Do you mean a wide angle zoom? Try the Canon 16-35 f2.8 L lens. On the 5D that 16mm is pretty wide.
Tokina does have a new full frame lens, a 16-28. Probably cheaper than the Canon, but no filter threads. http://www.tokinalens.com/products/t...28profx-a.html |
Ansab,
I use the 17-40 L f4 lens an awful lot. I'd like to upgrade to the 16-35 f2.8, but it is considerably more expensive. The 17-40 is very wide, and quite affordable. It's just a little slow (ok, a LOT slow), though I don't hesitate to increase the ISO to 2500 regularly on the 5d2, and all the way to 6400 if I have to. If you buy a good used one, you can use it till you can afford a 16-35 f2.8, and then sell the 17-40 as they are a good popular lens (I read somewhere that it was Canon's best selling lens). |
-- peer |
Just a quick addition to the discussion: the Tokina 11-16 does work on a 5DII. You'll need to stay at the longer lengths (about 15mm+) to avoid vignetting.
