5d Video shooting and shutter speeds and wide angle lens recommendation
Question,
For shooting video with the 5D, what is the highest acceptable shutter speed that still looks smooth and does not strobe? I am using the following canon lens: 50mm 1.4 24-105mm f4 70-300mm 4-5.6 100mm macro 2.8 Thanks! Also, any suggestions for an fairly inexpensive wide angle lens (maybe 12-24mm or something like that) I know sigma makes this one: Used Sigma 12-24mm f/4.5-5.6 AF Lens 200101 - B&H Photo Video some good and bad reviews on it however.... |
I use this Sigma 20mm 1.8 and am in love with it:
Basically a 180 degree shutter is what we are used to looking at.
NTSC 1/60 PAL 1/50 24P ideally 1/48 but 1/50 is OK. Those will work well with your lenses. One rule to remember is the 7 second rule. Any object traveling all the way across the frame should not be faster than 7 seconds in order not to blur. This is for 24P but it is a good rule even for 25p or 30p. Of course all rules can be broken for effect. But these are standards we are used to. This means that a wide angle lens is more forgiving than a longer lens at the same distance, all moves are in effect slower. I hope this helps. I have a Canon 17-40 f4 L it is fairly inexpensive and I use it a lot, it is very high quality and uses 77mm filters like most L's. |
1 Attachment(s)
I am very tempted to purchase one of the cheap manual Samyang 14mm f/2.8 aspherical lenses that are sold under various brand names. They get good reviews & the look of video shot with a 14mm wide angle on the 5DII should be spectacular.
Samyang 14mm f/2.8 IF ED UMC Aspherical - Full Format Review / Test Report |
Also, don't forget that if you're shooting 60p on the 7D/550d/T2i and plan to half the framerate in post, you'll need to set shutter to 1/120... Kris |
Silas, to clarify, if you're shooting 24p video your shutter speed should be 1/50. If you're shooting 30p it should be 1/60. And as mentioned, if you're doing 720p60 for slomo, use 1/120. If you shoot video at a higher or lower shutter speed, you'll get blurring or strobing, although if nothing is moving very much and you keep the camera static, you can sometimes get by with some variation in shutter speed. If you want a certain effect, experiment with different speeds and see what you get.
Lots of still photographers who have never shot video aren't too familiar with ND filters. You'll need at least an ND.9 for bright sun, maybe a 1.2 if you want to open up more. I use a .9 and add a .6 sometimes if I want a very shallow DOF outdoors. I often use the .6 inside for the same purpose. So, when shooting video, you don't use shutter speed to control light--that's what ND filters are for. |
The one exception to the above rule is for fluorescent lighting. Shoot 1/50 in 50 Hz countries (Europe, China, Aus...) and 1/60 in 60 Hz countries (North America, parts of Japan...) This will help you avoid flicker. In daylight, shoot with a 180 degree shutter, as Bill and others recommend.
This assumes that you want a "normal" film look. You can shoot with a faster shutter for a crisper, stuttery look. |
-- peer |
But he's not dispensing general creative advice - those are the exactly what the shutter speeds "should be" if you want the highest shutter speeds that "look smooth and do not strobe", which is what the original question was.
-- peer |
Re: 5d Video shooting and shutter speeds and wide angle lens recommendation
What nd filter power do I need to shoot at 1/60 when my camera exposure is yelling it needs 1/8000 - out in the sun at noon.
I want to use wide apertures like 1.4 or 1.6 |
Saif, I guess I've never shot with a shutter speed above 200, or so. Run a test. I would try to stick with the 180 rule, and if shooting in 24/25 fps, go with shutter speeds that are multiples, so 50, 100, 200, 400, 800.
Add in a modest ND filter and I would hope you'd get what you want. Nigel, we use the Rokinon 14mm f/2.8 and am really happy with it. Generally we use it on our crop factor camera, though, for a 20mm equivalent. |
| All times are GMT -6. The time now is 04:19 PM. |
