-   Canon EOS Full Frame for HD (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/)
-   -   5DMk11 won't display properly through Matrox Mini (https://www.dvinfo.net/forum/canon-eos-full-frame-hd/472291-5dmk11-wont-display-properly-through-matrox-mini.html)
Tim Palmer-Benson February 5th, 2010 05:51 AM
I have the Matrox Mini connected to a Sony Bravia 1080p. 5Dmk11 footage injested into FCP through MPEG streamclip as ProRes LT won't playback back on the TV...plays fine in the FCP Viewer.
If I move the clips into a 601 sequence which already has Xha1 video on it, the 5D clips play back fine as part of that sequence.
Is this a bug with FCP or Matrox? The Canon is 1080p, the tv is a genuine 1080p display, yet it will only display "stills" and scrubbing when the Canon footage is on a timeline properly set up to display it. Matrox doesn't have an answer to this...do you?
I changed over from Black Magic to the Matrox Mini precisely because the Black Magic Intensity Card does not display 1080p and the Matrox Mini does.
Perhaps the problem is with the frame rates of the XHAI 29.97 whereas the 5D's 30fps?????
