Follow Focus for 5D
I have the indiefocus20 for my 5D and I'm looking to change the gear for more of a pro one (if you will).......somewhat thicker....it appears that the gear that comes with the unit is a little flimsy.......can someoone point me in the right direction where I can consider purchasing a new gear to swap mine out? thanks
Maybe not "pro" but Ive benn thinking about ordering one of these: D|Focus - The Affordable Follow Focus System
The redrock gears are nice and can easily be swapped to other lenses if needed.
Thanks guys........
The mounting is just not designed to fit between your lens and a rod system, or you have to invest in a new camera mount which elevates the cam higher. Moving parts are made of plastic with a very cheap feel and they are tiny, so even by looking at them you dont feel safe about using them. The whole thing looks like a basement garage product, which I think it is. The main marketing message is something like "proudly made in USA". Well, then I have seen a number of quality Chinese products. You dont pay much but you will get what you paid for. I am not saying the disgustingly overpriced "branded" systems have justified prices, those are way too high. It would be great to see solid quality between these two leagues. |
While back, when I was in the same situation, I spent ample time debating what follow focus to get -- I ended up with a fairly inexpensive one from CineCity which I'm (still) quite happy with: -- peer |
I too have the RR FF v1 and love it.
A bit heavy, but excellent gear. Some day I'll be able to justify buying the v2... but by then, there will likely be a v3 or 4. |
I found CineCity products extremely cheap low end quality imitation, they look good initially but they use recycled material which breaks down easily and even their shoulder support rubber handle is breaking apart after 4 months, I pick it up to work and my hand went black like I am holding a piece of charcoal.
Pay a bit more and buy decent stuff. |
I agree and disagree with the CineCity opinions mentioned above. Their shoulder support is rubbish (well, the one I got was) and so was the glidecam thing but the follow focus is OK. Not brilliant, there's a couple of mm play in it but it's smooth enough.
I wish it pushed into the focus by turning anticlockwise when on the left of the camera rather than pulling out. That way it would match the turning of the focus ring on the lens barrel. |
-- peer |
A few weeks ago I gave them a second chance and got some of their newer DSLR support stuff.. and to my surprise most of it was of much better quality. And I think the FF is really ok for most cases.. I mean I think it's rediculous to pay as much as the camera itself costs or even more just for something like that - of course I always use Chrosziel or other professional gear on a shoot with a decent budget. I'm sorry to say that but - at least from my experience - for example the Redrock stuff isn't just that much better to justify the higher price! |
| All times are GMT -6. The time now is 10:54 AM. |
