Video Rendering 101 Anywhere?
I've shot over 100 4-5 minutes clips - usually live performances - one song one clip.
I use a RODE SVM Mic and mostly 24-105 f4L IS lens. I use NeoScene to convert the MOV files to AVI files and then bring the AVI files into Sony Vegas Studio 9 PE tp edit and add titles credits etc. Recently shot a 6 minute wedding (outdoors) and produced a rather hefty WMV end product which I then uploaded to SmugMug. The client who has who knows what kinda computer or connection say they can't get the movie to run. I have cable moden and I have to let it download a little before i try to play it myself. Question: What's the best bang for the buck as far as HD render formats? I've heard MP2 is HD - is MP4 HD - is there an optimal rendering format for web that can show a medium size picture that will just run on a decent connection? Also lately my videos played on Vimeo seem to accentuate the jerkiness whereas the same video uploaded to YouTube looks better and the video played on my bos is pretty smooth...and ideas? I'm learning but seems I have more questtions than answers at this point. Thanks Harry |
Videos uploaded to Vimeo are no longer in the native file format. They are all converted to a standard h.264 file at a standard rate. So if it's jerky there, it's not your original file that is at fault. I have no idea what smugmug does.
Thanks for the quick response......YouTube's conversion is kinder. I there a best output from Vegas Studio 9 PE where the conversion doesn't screw up the video so badly?
Harry |
Read this
Read this at Vimeo. I've used the same settings for SmugMug: Compression guidelines on Vimeo
Here's a link to my settings, you may have to play with the target bitrate to keep it under their files size limitation: http://arnica.csustan.edu/mtbike/5dvideo/h.264.jpg |
SmugMug converts to H.264 at a bit rate of around 7.5 Mbps for 1920x1080, 3.2Mbps for 1280x720 & lower bit rates for lower resolutions. I have excellent results with exporting from FCP in ProRes 1920x1080 & then converting to H.264 at 8Mbps before uploading to SmugMug. The SmugMug converted files are identical in quality to the originals & are faster to upload than if you upload files created at a higher bit rate. http://www.barkersvideo.com
This may be the missing piece. I've been rendering to WMV from the Cineform converted AVI that i edit in Vegas Studio 9 PE. Anyone know what the H.264 equivalent would be? What is the extention on the rendered file?
Thanks so much for helping me! Harry |
