Software rack focus at DVinfo.net
Canon EOS Full Frame for HD
Old July 14th, 2009, 10:46 PM   #1
Wizard Status
Software rack focus
I've posted a short video showing an upcoming Magic Lantern feature: software focus pulls. This is a demonstration of how smooth the software control can be with a very fine step size. It is doing 30 steps/sec in the video with a stepsize of 1 and speed of 1.
Magic Lantern - Software rack focus test on Vimeo
Tramm Hudson is offline   Reply With Quote
Old July 15th, 2009, 12:17 AM   #2
Great work Tramm. Very smooth video clip, had to play it back to see the focus change.
Does the camera register what step position the lens is currently at? I mean can you preset a step position 1 and 2. Can this also be routed to the bottom dial/wheel?
This has the potential to be a great ML feature.
Well done, you must be totally consumed with the camera.
James Miller is offline   Reply With Quote
Old July 15th, 2009, 12:36 AM   #3
This is amazingly cool.
Any idea of how to do the user interface? I see two possibilities, one that's self contained and another that uses external control.
For the self-contained version, having a single button press (even better - IR trigger for use on a gimbal rig) to start a pre-programmed rack focus would be excellent. The distance and duration could be loaded in a (the) config file. An S-curve could be applied, either in-camera or baked into a config sequence.
The extra step of loading the parameters into the card isn't too bad. Setting up a dynamic rack focus shot takes a fair amount of time to setup anyway. A minute of burning a file on the card would be well worth it to get a butter smooth transition with a perfect end point.
Multiple transitions - each manually triggered - would be amazing.
Jon Fairhurst
Old July 15th, 2009, 01:10 AM   #4
Tramm, that is brilliant. How are you currently setting the start and end points?
Do you think you in future we could integrate this with some kind of controller app for PC, Mac, pocket pc or Iphone?? I know that pocket phojo on windows mobile can control some camera functions so it may be possible without a proper computer or netbook, if we could connect a device like this to the camera and then control it from another on a peer-to-peer network it would be amazing.
Dan
Old July 15th, 2009, 06:11 AM   #5
Wizard Status
Right now they are open loop. My program just iterates 512 steps at 30 Hz in one direction when the "Rack focus" menu is selected. I may add something similar to the older Canon DEP mode -- you could manually rack the focus to the start and end points, have the camera record the positions and then execute the rack at the desired speed. Or, as Jon mentioned, maybe something in a script on the CF card.
Or perhaps a standalone device of some sort with a really nice focus knob and controls for all the other camera functions. If the camera is on a jib or a steadicam this would be very, very handy.
I would really like to track down a WFT-E4. The 5D Mark II has a full TCP/IP stack with a built-in webserver. Think about the possibilities there!
Old July 15th, 2009, 07:16 AM   #6
I am confused. Do any Canon lenses offer external control of the focus? I didn't think that was possible. Or are you sending signals to some other device?
me@facebook: http://facebook.com/stevemallerphotography
Steve Maller is offline   Reply With Quote
Old July 15th, 2009, 07:23 AM   #7
Tramm, if this is what you do in your spare time, what is your real job :) We all appreciate the tools that you are creating for us!
Chad Dyle is offline   Reply With Quote
Old July 15th, 2009, 08:26 AM   #8
A precise remote follow focus without the lensgear & gearbox thing... just the Canon USM, that sounds awesome!
Tramm, great work and great ideas! I will donate some $$$ for sure.
Dennis
from Germany
Dennis Doerr is offline   Reply With Quote
Old July 15th, 2009, 08:56 AM   #9
Of course. That's how they provide autofocus to still photographers. The camera sends the signal and the lens has the motor.
Jon Fairhurst
Old July 16th, 2009, 10:51 AM   #10
would the Magic Lantern void the Canon Warranty,
Hugh Mobley is offline   Reply With Quote
Old July 16th, 2009, 11:02 AM   #11
Tramm, That is AWESOME!
I had programmable buttons on my old Sony Z1u, where I could set up Button 1 for X focus and then Button 2 for Y focus and then rack between the two. I really missed being able to do that, and here you come with that feature for our 5DM2! That's brilliant!!!
Matthew Roddy is offline   Reply With Quote
Old July 16th, 2009, 11:08 AM   #12
Very nice Tramm
Some exciting possibilities there I think
Avey
Wayne Avanson is offline   Reply With Quote
Old July 16th, 2009, 11:37 AM   #13
Magic Lantern does not burn into the ROM, so it is similar to the CHDK firmware project.
You can read about how CHDK affects the Canon Warranty here:
FAQ - CHDK Wiki
From a practical standpoint, I doubt that Canon service would be able to detect if 3rd party code had ever been loaded.
Jon Fairhurst
Old July 16th, 2009, 12:01 PM   #14
I've been using Nikon (all manual) lenses, with this I may have to change. I'm guessing there is no motor function to the Canon zoom lenses. If I'm wrong and I hope I am, would this allow programed zooms (not that the world hasn't seen quite enough zooms already - but just in case one more is needed).
Denis OKeefe is offline   Reply With Quote
Old July 16th, 2009, 12:14 PM   #15
Wizard Status
There is the incredibly rare 35-80 mm f/4-5.6 PZ. I don't know if the zoom functions can be commanded through the EF lens protocol or if it only zoomed in response to the buttons on the lens body. I don't see any mention of it in the 5D Mark II firmware.
