Inexpensive audio solutions? at DVinfo.net
Canon EOS Full Frame for HD
Old February 26th, 2009, 09:43 PM   #1
I was just invited to a sponsor event for a project I'm in pre production on.
No money at all yet and won't start rolling til next year.
I may have an opportunity to do some interviews at this event that would be useful in a short teaser that may help in fund raising.
I've decided to take along my 5DII in case I do get a chance do do these interviews.
I'd like to pick up a lav, shotgun and two channel digital recorder because I'm concerned about not being able to monitor the audio out of the camera.
Would appreciate suggestions for a system in the $1000 - $1400 range total.
Dave
David C. Smith is offline   Reply With Quote
Old February 26th, 2009, 09:48 PM   #2
As far as audio recorders go...
I have the Zoom H4 but which works well but the interface / menus / buttons are pretty terrible. I am looking to get a MicroTrac as a replacement. I read mixed reviews about all of the small recorders but those were my two finalists.
http://www.michaelfriedman.org/
Michael Friedman is offline   Reply With Quote
Old February 26th, 2009, 09:59 PM   #3
I thought this looked interesting as far as recorders go.
Tascam | DP-004 Digital Pocketstudio Portable | DP-004 | B&H
It has a mini jack for a headphone output.
I'm thinking of splitting the output and running it to both the 5DII for a scratch track and a set of cans for monitoring.
Old February 26th, 2009, 10:37 PM   #4
That's a good find, although I am not sure I would want to give up the option of using my old phantom power mic when I need to. I do like the idea of physical knobs though. It also appears to be 44khz only. That may be a deal breaker.
Old February 26th, 2009, 10:55 PM   #5
I would add the new Edirol R-09HR to your shortlist. R-09HR High Resolution WAVE/MP3 Recorder
I know the BBC has started using these for some applications and I find the previous model to be very good although lacking phantom power.
Dan
Old February 26th, 2009, 11:27 PM   #6
Isn't the Edirol one channel, not two?
Old February 27th, 2009, 01:57 AM   #7
We use the Microtrack II. It supports two channels of balanced inputs with phantom power. The inputs, however, are 1/4" TRS. You need a pair of XLR to TRS cables, which cost about $15 apiece.
The headphone output works as a monitor, but only when actually recording. You have to hit record and then set levels. This is good in that it ensures that you never get your start and stop recording button presses mixed up.
The preamps aren't noise free, so it's still important to set your levels properly - even at 24 bits. Fortunately, the noise footprint of the device can be removed from the signal *very* cleanly with standard noise reduction software. (I use SoundForge 9, but I'm confident that most any modern NR software will do the trick.) I've had many recordings with noise footprints that don't remove cleanly - and that leave dialog sounding underwater. This noise is as clean to remove as any I've ever encountered.
Jon Fairhurst
Old February 27th, 2009, 09:17 AM   #8
I second the H4
For the money - it's a great recorder and you can use it with XLR mikes too - Yes - the interface is a little "quirky" but once you know it - it's fine
Tom
Tomaso Perrone is offline   Reply With Quote
Old February 27th, 2009, 11:25 AM   #9
DVCreators.Net
Kickin' around the idea of the HHB Flashmic YouTube - HHB Flashmic - MP3/WAV microphone with 1GB memory
There is a cardioid version out now.
Guy Cochran
Old February 27th, 2009, 11:57 AM   #10
There is a new version of the Zoom H4 comming out the "Zoom H4n" looks good
Samson - Zoom - H4n
Brian Leahy is offline   Reply With Quote
Old February 27th, 2009, 01:37 PM   #11
Samson - Zoom - H4n
Saw that but, it's not available yet and I need something by March 7th.
Dave Smith
Old February 27th, 2009, 01:40 PM   #12
Anyone work with this?
Fostex | FR-2 LE - 2-Channel Compact Flash Field | FR2 LE | B&H
A little pricey but it uses CF cards instead of SD. I wouldn't have to buy new cards and a reader.
Dave Smith
Old March 1st, 2009, 10:56 AM   #13
I just got the sony PCM-D50 and it works great. It dosn't have XLR inputs though. This isn't a problem for me since I use a sound devices MixPre as the preamp. In my opinion no sub $1000 recorder with built in preamps is going to come close to the quality of the MixPre. It is a little bit of a hassle to have 2 boxes but its a lot cheaper than the Sound Devices 702.
John Saunders is offline   Reply With Quote
Old March 2nd, 2009, 02:02 AM   #14
Originally Posted by David C. Smith View Post
The FR2 LE is a great unit. I haven't yet used mine in conjunction with the 5D mk II, but it's high on my list of things to try (now that I can edit the 5D mk II files in Premier Pro CS3, thanks to Cineform's Neo Scene!).
Julian
Julian Frost is offline   Reply With Quote
Old March 2nd, 2009, 07:47 PM   #15
Anyone tried the Marantz 661? I've read some great reviews about it on the web.
Marantz | PMD661 Professional Portable Flash Field | PMD661
Dana Rice is offline   Reply
