Banding in video at iso 3200? argghh
Try this with your 5D2.. force it go to into ISO 3200 and aim it at a relatively dark surface, zoom in to 10x and do you see horizontal banding moving in a vertical direction? I've tried this in tungsten lighting indoors and sodium lighting outdoors so I don't believe it is a lighting flicker issue..
Yes, the high ISO capabilities are quite pointless with other than RAW photographs.
I wonder if upgrading to firmware version 1.07 would help this issue? Part of that update was a fix for banding in sRAW format.
Have you guys confirmed this to be true on your 5D2s? Or are you just commenting?
Also keep in mind that I was able to see the banding at 10x zoom. With about 5-6 bands on the screen at any given instant, so we're talking about very high frequency banding. I tired it again later last night and I wasn't able to observe the same banding. I'm still on 1.0.6... Will not upgrade to 1.0.7 due to the magenta color cast issue. |
Someone said that the sensor needs to burn in but I don't believe that. I'm on the 1.07 firmware. What is the magenta color cast issue you talk about? T |
| All times are GMT -6. The time now is 03:44 PM. |
