Nikon Lens Question
Ok I have an adapter and a Nikon lens with the aperture ring. All works well, but the camera still wants to make adjustments when I move the camera around. Like pointing towards a window and the picture goes dark. Is the camera adjusting something other than aperture? What am I missing? I feel there is something obvious going on here that needs to be set up. Please help.
Bruce Cleveland |
Hi Bruce,
The key is to press the AE Lock button. It will lock your exposure. I recommend this (from memory - I hope I haven't left anything off) * Use the Video + Stills mode (under the Live View menu) * Enter Live View * Press the shutter button part way. You want to see the exposure compensation (-2..|..+2) adjustment on the screen. Press "Info" a few times, if needed. * Dial the wheel so that exposure compensation is at -2. * Shine the camera at a light, as soon as it gets to 1/40 shutter, press AE lock. * Point the camera at your subject and increase the exposure compensation at needed. The ISO (gain) should increase, and the shutter speed should stay the same. * Start recording! You'll need to do most of this for every single take. Hopefully, Canon will upgrade the firmware to allow a better user experience. |
Thanks for the imput. Bruce |
Ok got it. Thanks for clearing it up. Just wanted to make sure I wasn't missing anything. Bruce |
So as soon as you stop recording, everything resets? Or can you start/stop with all of it locked, only needing to go through all those steps again if you want to CHANGE one of the settings?
Bruce |
| All times are GMT -6. The time now is 07:53 AM. |
