Canon 5D Mark-II Stuck Pixels...
On my quest to purchase a new 5D-MKII, I went to 2 retailers and tried to bodies with random exposure with the lens cap on from 800 ISO to 6400 ISO at about 1 sec. exposure time only to be devastated when analyzing the results both cameras had stuck pixels. one body had 4 stuck pixels (3 large white ones covering the surrounding area of approx. 4 pixels total and one single red one). The other body had 2 white stuck pixels. The stuck pixels are even perfectly visible at 400 ISO and a normal exposure time when looking for them and also when shooting video. This is quite unbelievable.
I performed this test specifically to try out the cameras before a purchase but was expecting clean results honestly. has anyone experienced similar problems? is there a simple way to fix them or doing a CMOS remap? I am totally appalled at this! I own (2) 1Ds-MkII and (1) 1Ds-MkIII and they are pitch perfect! |
The reason is that Canon has an undocumented feature: The mirror will slap up, take an exposure to find dead/hot pixels, update the dead pixel map. This is obviously done at the factory, and gets updated anytime you clean the camera. Unfortunately, hot pixels do not seem to be quite so easy to fix for video. There are many reports of hot/dead pixels in video that don't get fixed by the manual sensor clean. |
so taking the camera to Canon will fix this
So taking the camera to Canon Factory it will fix this problem, they also told me that it could run up to the 900 dollars to change a cmos or Low pass Filter.
on the sensor. |
I personally had a stuck pixel in video that could not be fixed via the user remap, it required Canon servicing (I also had other lockup problems err something or other). I sent it in, they fixed it, door to door was 2 weeks, it's been fine ever since. Not a good thing for a brand new camera, but I must say I love the thing and it's been working flawless ever since, so there you have it. You're doing the right thing though, much better to never have the problem to begin with.
double post, please remove/
I haven't sent mine in for the one that I have, and probably should. However, it is only apparent in low light shooting, and can be readily edit out easily in most situations. Seems like it is happening less and less, though I don't know why
I agree, I should still send it in. |
How can you be sure that what you are seeing is stuck pixels without cleaning the sensor or even the lens?
I my case it has been in the same place since I got it. It is also brighter that other pixels. I would expect dust or dirt to be black.
Quality control CANON bad!
Canon EOS T1i with less than 100 clicks already has 7 dead pixel and 4 stuck pixel!
Quality control CANON bad! Look the uploads: original image: ORIGINAL defective posted image: DEFECTIVE My other camera Canon PowerShot S5IS had the same problem after 2 years of use and cost me $ 220.00 to do a mapping of the CCD with a Canon authorized Brazil. I'm starting to be disappointed with Canon, Nikon also has these problems common?! William Brazil |
My first 5D Mk II definitely had an issue with this — it was either a stuck or dead pixel, but pretty darn visible, especially in dark/night shoots, there would be a bright violet pixel in the lower right quadrant. It was correctable in post, but oh, what a pain...
It was under Canon warranty but I ended up taking it back to BestBuy. Fortunately, they gave me a new one, without voiding the existing warranties. I feel VERY lucky, but I am indeed concerned about something like this happening again. I hope Canon addresses this problem more publicly in the near future. |
I hadn't seen the dots connected here. I found this in another forum and thread. Fix stuck pixels in post. I just wanted to share the solution I'm using on footage with stuck pixels, thanks to Adam Wilt and Andy Mees links.
http://www.dvinfo.net/forum/1302329-post8.html ProVideo Coalition.com: Apple | Vendor Blog http://www.adamwilt.com/downloads/AJW's%20Filters.zip |
| All times are GMT -6. The time now is 09:25 PM. |
