Stop Motion
I just did a 5 second test of a simple item rotating. I put the item on a tripod and took a still, rotated the tripod a smidg and then snapped another pic, etc. The speed of the anim looks fine. I wouldn't need it to move any faster or slower, but BOY does it look like stop motion (very jittery).
Assembled from a JPEG Sequence in AE CS3 at both 720/24p as well as 720/29.97i. Are there any sites that talk about stop motion or where might I find advice regarding stop motion with a DSLR? Thanks very! |
Add in some motion blur, AE shoud be able to do that. Frame blending of some sort would help too. Else just shoot more frames of the rotation.
T |
Matthew
You could always try experimenting with longer exposure times, this might help smooth some of the motion and make it less jittery. StopMotionAnimation.com is a pretty good resource for all things stop frame. Adrian |
Thanks very much to you both.
My interlaced project was a lot smoother than the 24p project. I also noticed - and let this be a Matthew-learned-lesson to there would-be animators out there - that part of my jitter was me stepping on the carpet near my tripod when I shuttered the camera. There was just enough cush in the carpet that it moved the tripod, making each frame a little different. Nasty stuff on the brain. So, lessons learned: Use Interlacing Apply Motion Blur Where Necessary STAY AWAY FROM THE DOGGON CAMERA WHEN RELEASING THE SHUTTER (Same thing when moving the object) Seems like no-brainers in hindsight, but hey... I'm a slow learner. That web site looks awesome! A definite bookmark! Thanks! |
Thanks, Evan. You're absolutely right. Fortunately, I remembered that from my Super8 daze. I had a wired remote, but I still had to step within a foot or two and that was enough to push the carpet.
