-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   70D message - "movie recording has been stopped automatica​lly" (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/519149-70d-message-movie-recording-has-been-stopped-automatica-lly.html)
Bob Ohlemann September 25th, 2013 08:56 AM
I am using a PNY 32GB class 10 SDHC rated at 30MB/s. I was recording 1920x1080 at 24fps all-i which is the lower compression format. Is the card too slow or could there be some other issue here? These cards work fine in my XA20 at 35Mb/s.
Bob
Mark Rosenzweig September 25th, 2013 09:14 AM
Re: 70D message - "movie recording has been stopped automatica​lly"
Did you format the card in the 70D, using low-level format before using the card in the 70D?
Bob Ohlemann September 25th, 2013 10:09 AM
I did. Looking at the manual, it says I need at least 20MB/s. I'm thinking that my cards are actually 30MB/s read and 20MB/s write. I may be just too close. The manual gives no other explanation other than SD card not being fast enough.
Bob
Donald McPherson September 25th, 2013 10:20 AM
Could be a forgery SD card. Apparently there are loads sold on eBay.
Robert Benda September 25th, 2013 11:25 AM
or your camera is overheating. Our 70D also refused to record, but we had been using it off and on for a few hours, so for now, I'm assuming it's a heat issue, but will keep an eye on it.
Mark Rosenzweig September 25th, 2013 02:07 PM
Bob
20MB/s=160Mbps. That is a really high bitrate. Is that what you are shooting?
Bob Ohlemann September 25th, 2013 02:56 PM
I don't think it's overheating. I have recorded exactly five clips with it; all under 45 seconds (not counting the clip described below).
I downloaded and ran a speedtest program on my SD cards and came up with some interesting information. The max write speed on my PNY "High Performance" 30MB/s was only 9MB/s as tested through a USB2.0 card reader. I thought maybe the card reader was limiting the write speed so I plugged a UDMA 600x Transcend CF card and got a write speed of 14.5MB/s. I do believe that is limited by the USB2.0 connection. So then I plugged in a PNY "Professional" 20MB/s SDHC card and got a write speed of 11.9MB/s. The slower advertised card had a faster write speed.
I plugged the 20MB/s card into the 70D, did a format, and recorded a 3.5 minute clip with no issues. I have now ordered a couple Transcend 32GB 80MB/s SDXC cards.
Bob
Bob Ohlemann September 26th, 2013 06:16 AM
Looks to be about 91Mbps.
Bob
Michael Bishop September 27th, 2013 08:49 AM
I pick up a 70D the other day. I seen where your talking SD cards. I shoot a little clip yesterday at the IPB. Windows says the total bitrate was 31859kbps. This morning I try shooting a clip at All- I mode. I had a Scan Disk Ultra 30MB/s' card in. It would only record for about 4 seconds. Windows said the total bitrate 94128kbps.
What cards or speed of card will work for the All-I mode?
Media info says the video stream is 87.9 Mbps for All-I mode.
Robert Benda September 27th, 2013 09:06 AM
Wow. Guess I didn't count on that. I do have some SanDisk extremes that write up to 60mb/s. They also have an Extreme Pro that writes at 90mb/s
Bob Ohlemann September 27th, 2013 09:59 AM
I believe a class 10 card is only required to write at 10MB/s. That is not fast enough for All-I recording on the 70D. The manual says 20MB/s and it means 20MB/s. The problem is a lot of the numbers on cards are over-inflated. I went with Transcend 600x cards with a advertised 45MB/s write speed and 80MB/s read. I've always found Transcend cards to be excellent.
Bob
Craig Chartier September 27th, 2013 09:59 AM
Hoodman makes a very good SD card. 32gb 90mb/s works with the 70D, BM pocket cam and the XA-20 just fine for me.
I've also heard of the fake cards not performing up to listed specs.
Mark Rosenzweig September 27th, 2013 10:01 AM
Megabytes and megabits
There is much confusion because sd cards give you speed in megabytes and bitrates are given in megabits. There are 8 megabits per megabyte.
Thus 87.9 Mbps = just 11MBps (megabytes per second). Thus a card rated for 30MBps should be more than fine. The card speed rating (if it is correct) is NOT the problem.
Bob Ohlemann September 27th, 2013 10:17 AM
The problem is even authentic, name brand cards like the PNY I bought from Best Buy, aren't completely forthright in their speed ratings. My 30MB/s PNY cards only said 30MB/s on the card and packaging. There was no indication as to whether that was read or write. I did a lot of digging yesterday after posting this problem and it turns out that the card is only rated at 10MB/s write speed. After testing two of them with a read-write speed test program, neither got above 9.25MB/s. They really don't even qualify for class 10 rating.
I am getting by right now on a card that gave me just under 12MB/s in testing but, I'm recording at 24fps. I suspect that if I bumped my frame rate to 30, it might not work.
Bob
Added - I just took a look at the Sandisk website and they are just as vague. The 30MB/s Ultra just says "Performance/speed: Up to 30MB/s read speed; write speed lower"
Michael Bishop September 27th, 2013 05:52 PM
This evening I put in a Kingston Ultimate 100x 32 GB SD card. I got it back in 2011 for a HD GoPro camera and it keep recording at the All-I mode. At 30 fps. I can say oh that a guy would need a few of those cards file size was 1.80 GB for 2 minutes and 57 seconds of video.
Johnny Wu October 5th, 2013 04:23 PM
My class 10 sd card that works well for the 5D3 and 60d is not fast enough for the 70d. One of them is the Sony 45MB/s write and was working well so I went and got myself annoyed one. Amazon.com : Komputerbay 64GB SDXC Secure Digital Extended Capacity Speed Class 10 UHS-I Ultra High Speed Flash Memory Card 45MB/s Write 60MB/s Read 64 GB : Computers & Accessories
