-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   7D Stutter issues (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/506626-7d-stutter-issues.html)
Stuart Meed April 3rd, 2012 01:50 PM
7D Stutter issues
I cannot seem to get good looking video at 24 or 30 fps. Any panning at all creates stutter. I can even see this happening in the LCD. Moving up to 720/60 fps eliminates this issue.
My first thought was that my CF card was too slow but a quick Google search shows that my SanDisk Extreme 60 MB/S 32 Gig card should do just fine.
I've set up my 7D as shown here
Please help!
Daniel Epstein April 6th, 2012 10:34 AM
Re: 7D Stutter issues
Stuart,
What shutter speed are you using for your 24P and 30P footage? Double the frame rate is typical. I use 1/60th for 24P a lot to avoid flicker. If you are using much higher shutter rates you will get choppy motion on moves. It is easy to pan and tilt fast enough to cause issues. Does the video stutter on motion when you are not panning? You do have to make compromises for motion when using different frame rates.
Stuart Meed April 7th, 2012 07:33 AM
I'm mostly using 30 but some 24. I know that these cameras misbehave a bit when panning but I see others with the same camera getting much better results and cannot understand why.
Yes, I'm using the 180 rule for shutter speed. I don't have any issues when I'm not panning.
I don't need perfect, fluid pans, I just want my video to be as good as the next guys!
Chris Medico April 7th, 2012 08:21 AM
What is your panning rate? You should be panning so something does not cross completely though the frame any faster than 5-6 seconds.
Can you post an example showing your issue?
Stuart Meed April 7th, 2012 09:28 AM
Chris,
No faster than 5-6 seconds would probably eliminate my issue. I just sometime see really great footage and then see it was done with a 7D and think, "How did they do that?"
The footage appears 24-30 fps.
Daniel Epstein April 7th, 2012 12:53 PM
Hey Stuart, Sometimes the screen doesn't give you the true feeling of the shot. You should try some test pans at different rates and see what they look like on a different display. You may be pleasantly surprised.
Stuart Meed April 7th, 2012 02:44 PM
Yeah, I need to play with it more and find it's limitations.
Thanks for the suggestions.
