-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Has anyone used Magic Lantern on a T3i/600D yet? (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/502527-has-anyone-used-magic-lantern-t3i-600d-yet.html)
Harry Bromley-Davenport November 9th, 2011 07:45 PM
When I last checked, people were posting that Magic Lantern was not yet ready for primetime on the T3i.
Has anyone done this yet and is it working ok?
Harry.
Matthew Macomber November 10th, 2011 06:24 PM
Re: Has anyone used Magic Lantern on a T3i/600D yet?
Works great for me. It seems to be just as stable as magic lantern is on my T2i, however it has unfinished audio controls. Everything else related to image/shooting works well.
Harry Bromley-Davenport November 10th, 2011 06:27 PM
Does it display live audio meters on viewfinder screen?
By the way, I'm having a bad time installing it. If you know of an installation tutorial for idiots I would appreciate it.
Thanks for the reply,
Harry
Reuben Miller November 10th, 2011 07:49 PM
I've been using it for 2 weeks - the same amount of time I've owned my T3i. Works as advertised - I must admit it's been quite a journey these last 14 days... First DSLR, and I loaded ML immediately :)
I love it! BTW... audio meters work just fine during recording.
Cheers!
Iker Riera November 10th, 2011 08:55 PM
anyone knows if the focus peaking option works well and if it appears on an external monitor?
Reuben Miller November 10th, 2011 09:18 PM
focus peaking works well - don't have an external monitor yet ;)
James Donnelly November 11th, 2011 10:17 AM
External monitor support has been improved with the last few updates.
There is a force VGA mode for HDMI out which makes pretty much everything work, and it works great in SD from the USB output. It may also work in full HDMI mode.
Brian Tori November 11th, 2011 10:58 AM
So no audio monitoring via mini USB to headphones yet? Does anyone know if this will be available soon?
Ger Griffin November 11th, 2011 12:59 PM
Alex, the current developer doesnt actually have a t3i so this will inevitably hamper any progress.
Jordan Hooper November 11th, 2011 01:01 PM
Harry, all the install info is here. Unified/Install - Magic Lantern Firmware Wiki
I think the instructions have been simplified as much as they can be. Just make sure you follow every step and make a checklist if it helps.
Reuben Miller November 12th, 2011 10:43 AM
Harry
An installation tutorial video is located here: Magic Lantern Install Tutorial - Magic Lantern User Group on Vimeo
Taky Cheung November 12th, 2011 11:01 AM
I have been using it. Audio control is based on T3i internal audio settings, which works fine for me.
Focus Peaking would go crazy when using the 3X crop zoom. If using it on and off, the entire screen will be fill with dots. I have to turn off the camera to restore focus peaking functionality.
Otherwise, the focus peaking and non-stop recording are the best feature I need from ML.
Ger Griffin November 12th, 2011 05:27 PM
Agreed Taky, another good one I find lately is under power save. Have the screen go into standby after 5 seconds of idle when not recording. Prevents me from thinking camera is recording when it isnt. I dont think its the intention of that setting but it certainly is a good by-product.
Reuben Miller November 12th, 2011 06:56 PM
Don't forget "True" ISO's ;)
Taky Cheung November 14th, 2011 12:18 AM
I'm using the Unified version dated Oct 27.2011. Yesterday was the first time I encountered some mishap. One of the 18 SD cards that I have stop responding. The camera will display a live view and ML won't loan. Nothing can be done. Turning off the camera won't help too. Have to remove the battery. Luckily all the footage were still fine in the card. =)
Also, I don't know what buttons did I press wrong. Sometimes the screen will display the four cursor keys to adjust +/- ISO and +/- Color Temperature. Sometime that doesn't show. ... dont know.
Also one complains I have is there';re way too much info on the screen overlay on top of the original T3i display. From experience, when the battery gauge is showing half empty, it's time to change the battery. However, that display is now being blocked.
