UV filter recommendation for 60D
Hi,
I just got the canon 60D and I want to get an UV filter. Basically to protect the front of the lens. I have the 18-200 Ef-S lens. I have been doing a little research and it looks like I am down to either the Hoya hmc UV filter or one of the B + W filters. I have read that there are two issues with the Hoya. 1 - The Hoya has aluminum threads and it is easy to cross thread when taking it on and off. 2 - hard to clean. My other criteria is no vignetting and as little as possible light loss? If you recommend the B + W more can you supply the filter model number. I have used on my Canon10d and my Sony FX-7 just the cheep Tiffen UV lens filters. I don't see any problems with it not being high quality. The images look very crisp and clear. But then again I have never really played around with filters. The Tiffen does sometime miss thread but that has not been a big issue for me since I don't take it on and off very much and I am very careful to have a light touch not to miss thread the filter. Thanks, John Gerard |
Re: UV filter recommendation for 60D
I have the Hoya HMC Super Multi Coated UV filter on each lens I use frequently, for two reasons. Front element lens surface protection (I've seen two cases where the filter took an impact that would have ruined the lens), and that level of Hoya's multicoating seems to significanlty reduce flare as the lens is point off axis but in the general direction of a bright light source.
I ran tests with a Canon HF100 panned 360 degrees first with a Tiffen multicoated UV (not a bad one either) and then with the Hoya HMC SMC UV. As the camera with the Hoya began to approach the direction of the morning sun, flare was noticeably reduced over the Tiffen. When pointed directly at the axis of the sun NOTHING HELPS! As far as "cross threading" goes, I never get in a hurry when removing or putting on anything that "threads in". Rarely do I have to remove the filter on location (only if I have to put on a wide angle adapter and having a 2nd HF100 lets me bring both on location configured for use). I find the Hoya filter surface no harder to clean than any other. The multicoating does "grab" cleaning cloth a bit, I use CLEAN microfiber cloth with "breath moisture" most of the time. Stubborn "stuff" gets taken care of with Eclipse solution (about the purest alcohol you'll get) on a Pec Pad (the same sometimes used for sensor cleaning). I've heard the B+W is an excellent quality filter, but I've had good luck with Hoya. |
Thank you for your thoughts. Have you compared the Hoyo Super HMC multicoated to the standard Hoyo Hmc filters? Is the Super version really worth the extra cost? One review I read didn't think so.
John Gerard |
Oh, one other small question. which model of the Hoya should I use on an 18-200mm lens so I have no vignetting?
John Gerard |
Didn't bother me to pay the extra, especially when two of the filters were going on "L" series glass. With the 7D a proper fitting filter on the "L" series lenses completes the "weather sealing". Quote:
If you have anything in that lens' filter thread size lying around, test it for vignetting. Bruce Foreman |
At the last moment I decided to get the B & w multicoated, I think it is the f-pro. I don't have any particular reason behind the decision. Thank you for all the advice. Either one seems like a good product. It sound like a goss up to me. I did ask B&H photo theiir advice. The guy said he uses B&W filters so I went with that brand.
John Gerard |
| All times are GMT -6. The time now is 09:04 PM. |
